backfiring and sputtering after installing alot of stuff
Old 03-27-2009, 10:35 AM
ebaker's Avatar
Default backfiring and sputtering after installing alot of stuff
So we just installed headers, custom y, and new plugs and wires. it was running right before all this but now its backfiring when im idling and at low rpms while im driving and at WOT it sounds almost like a misfire. i had patrick G tune the car for me and he checked everything plugs, wires, coils, injectors and everything checked out. is there anything that im missing? maybe a bent pushrod? i did a search but none of the things i found helped me out.
Old 03-28-2009, 07:04 PM
qwickLT1WS6's Avatar
bad opti! thats gotta be it
Old 03-28-2009, 07:59 PM
99T/A_Marine's Avatar
Originally Posted by ebaker
So we just installed headers, custom y, and new plugs and wires. it was running right before all this but now its backfiring when im idling and at low rpms while im driving and at WOT it sounds almost like a misfire. i had patrick G tune the car for me and he checked everything plugs, wires, coils, injectors and everything checked out. is there anything that im missing? maybe a bent pushrod? bad opti? i did a search but none of the things i found helped me out.
Your car doesn't have an Opti-Spark. Unless for some reason you put an LT1 into that thing.
Old 03-28-2009, 11:38 PM
LS6427's Avatar
You have no opti.
Make sure plug wires are not touching any of the LT pipes. That will cause a miss fire. Maybe a broken spark plug.
Old 03-28-2009, 11:41 PM
jattgunman's Avatar
You cracked the porcelian(sp?) on one or more of your spark plugs...Pull them out and look for any fineline cracks..You can rub some dirty grease or something to make the imperfection stand out
Old 03-29-2009, 07:27 PM
ebaker's Avatar
sorry about the opti comment....lol gotta love feeling dumb. ok im gonna try that out as soon as i can get with my friend kurt and use his tools. thanks for the input guys! i'll let ya'll know what happens
Old 03-29-2009, 07:45 PM
superfreakws6's Avatar
I had the same excact problem and it was a loose spark plug connector.
Old 03-30-2009, 08:51 AM
ebaker's Avatar
the thing that has me speechless is the fact that my car is only throwing one code(o2 sensors not switching over) but i just replaced the stock sensors with brand new vette sensors and its still running horribly. i havent seen any misfire codes pop up at all. im taking it to kurts shop wednesday and we are gonna see what the heck is going on
Old 04-01-2009, 08:55 PM
silverZ28_08's Avatar
Post
im having the same problem with my 98 Z28. i replaced the spark plugs and wires, but the car still stutters. no misfire code. i thought it was the tune, so i took it back and tried another tune but still acts the same. im gonna try replacing the o2's. at idle the car seems ok but driving it stutters. i dont know wat to do
Old 04-09-2009, 07:18 PM
Moderator
98Aggie's Avatar
problem fixed - come get it
Old 04-10-2009, 12:27 AM
rabbit320's Avatar
just did the same thing, race headers, y, o2 ext, new plugs wires, same issues... seems to shake more at idle. is it just dumping fuel because of deleted air/egr?
Old 04-10-2009, 09:14 AM
ebaker's Avatar
im going out to pick the car up in a second and i'll get the whole download and then let ya'll know what happened! thanks kurt!
Old 04-10-2009, 02:53 PM
98transamtx's Avatar
check the wires and spark plug, could be a bad coil too.
Old 04-10-2009, 02:55 PM
ebaker's Avatar
ended up being the wires. apparently the stock plug wires are much better than any aftermarket plug wire you can buy. runs like a champ with the stock wires on it now!
Quick Reply: backfiring and sputtering after installing alot of stuff
