Rear Defroster Not working tab fell of window
Old 04-07-2009, 01:47 PM
BKDZ28's Avatar
Default Rear Defroster Not working tab fell of window
I'm looking for some help. My rear defroster in my camaro is not working because the drivers side tab has fallen off the window in the rear. Can anyone recomended a product or a way to fix this.??? I believe a conductive epoxy or adhesive is needed? Thanks for the help Bryan
Old 04-07-2009, 02:13 PM
jsteele90's Avatar
press it against the window then take the superglue pens.(they have a very small applicator at the end) and run a bead around the tab. WORKED FOR ME
Old 04-07-2009, 07:50 PM
BKDZ28's Avatar
sounds like a good idea because it pulled off clean I will try that.
Thanks Bryan
Old 04-07-2009, 11:57 PM
The Guz's Avatar
I bought this repair kit that I used on my other car. Worked great.
http://www.frostfighter.com/
Old 04-08-2009, 11:45 AM
Save the manuals!
wssix99's Avatar
Solder. You will probably need a high wattage solder gun. (Not a soldering pencil, like you'd use with a circuit board.)
Post #4 in this thread has the procedure from the GM factory service manual: Rear defroster detached from Window, how to reattach?
An auto glass shop should also be able to do this for you cheap.
Old 04-09-2009, 08:18 PM
BKDZ28's Avatar
I'm going to call a local glass shop and let them do it! How expesive could it be? Thanks again for the advice
Old 04-10-2009, 01:16 AM
Save the manuals!
wssix99's Avatar
I wouldn't think too much. When you go, please let us know how much it runs you. (I'm curious.)
Old 04-10-2009, 06:08 AM
BKDZ28's Avatar
I def will. it will be a few weeks since my cars isn't on the rode yet.
Thanks Bryan
Quick Reply: Rear Defroster Not working tab fell of window
