turbo manifolds.
Old 04-07-2009, 01:53 PM
Juicemonkey's Avatar
Default turbo manifolds.
ok guys I finaly got my LQ9 built and dropped into my 240sx. Now I am going turbo, but the truck mani's dont clear the frame and body work, are there a slimmer type of gm manifold I can use? Open to suggestions.
Old 04-07-2009, 02:42 PM
smokinHawk's Avatar
the c5, c6, z06 manifolds to the corvette hug the block better and might work.
Old 04-07-2009, 03:05 PM
2001ws6-500hp's Avatar
yep the c5s are bigtime block huggers
Old 04-07-2009, 03:13 PM
lookin at a set on ebay right now for like 30 bucks, thats what i was thinking, thanks guys, I appreciate it.
Old 04-07-2009, 04:12 PM
2000extremeturbo's Avatar
Another idea might be 98 or 99 camaro manifolds. They are made of steel, and can be cut and welded easily.
Old 04-07-2009, 04:47 PM
just 98 and 99 mani's are steel?
Old 04-09-2009, 12:01 PM
347fbody's Avatar
ive got a set layin around i need to get rid of
Old 04-09-2009, 02:01 PM
Restricted User
98Z28CobraKiller's Avatar
The vette ones can't be used unless you use either motor plates or the vette style mounts. Fbody mounting location will not work.
Old 04-09-2009, 02:11 PM
MaxxMitchell's Avatar
I used a 02 Fbody manifold on the drivers side same as stock on that car. They hug closer to the motor alot better then a truck manifold, basicly dont kick out like the truck ones.
Old 04-09-2009, 04:09 PM
just picked up c6 manifolds today, real short hugger type and flanges dump out forwards if I flip them around. I should be good. thanks guys for the info.
Old 04-09-2009, 08:17 PM
dudeman's Avatar
if that doesnt work you could take mustang shorty headers and put ls1 flanges on and use them. there is a post on here somewhere that has some good pics!
Old 04-10-2009, 05:48 PM
letsrunem's Avatar
How far off are they? Can you cut of the flanges and weld on v-bands?
Old 04-10-2009, 06:55 PM
elias_799's Avatar
can you post up the link for all of us please ?
Old 04-10-2009, 10:55 PM
dudeman's Avatar
https://ls1tech.com/forums/forced-in...-progress.html
Old 04-12-2009, 01:24 PM
waiting for the c6 manis to come in, I will find out if they will fit. I have an s13 240sx im going to have to see if I can stick the turbo there too. I was going to put it on the pass side near the battery and just move the battery to the trunk. I dont have enough room to run a 4 inch downpipe on the drivers side. what size dp does that s14 have?
Old 04-14-2009, 12:34 PM
dudeman's Avatar
i didnt see one.
Old 06-20-2009, 06:11 PM
lewroe's Avatar
the s14 is mine, 3" bend is the downpipe. comes out in front of the drivers front tire...
gt45 turbo and the outlet was 3"
Old 06-20-2009, 06:40 PM
TurboAv's Avatar
I'm going to be using C6 manifold flipped backwards on my GTO. There is a build thread on LS2gto.com of a guy doing that on the east coast.
Old 06-21-2009, 01:09 PM
Turbo Cutlass's Avatar
if the flange is interfering with the frame cut them off and tig weld 2.5 stainless v band clamps on. Make sure you preheat it to 250 to 300 deg. the use silicone bronze rod or 308 rod. After you are finished wrap the welded area with a fiberglass wrap and let it slow cool for about 2 hours. Hope this helps. Mike Salkowski
Old 06-26-2009, 11:29 AM
91 240's Avatar
where exactly dont the mani's clear? do you have any pics of the clearance?
