cage question
cage question
so i have the dash removed for the cage install just waiting for my welder to return from florida. anybody have pictures or could get me some pictures of where it goes through the dash. it looks lik the fuse box is goin to be in the way? and id lik to see where it goes through on the passenger side. thanks in advance
unless you go way forward with the front runners i think the fuse box will get in the way.just put them as far forward as you can and possibly even notch out some of that front metal under the dash
unfortunatly i went mild steel didnt have the money to go chromoly and definatly didnt have money for a custom. so i bought the ms kit and a friend of ours whose a welder is gonna put it in.
thanks everyone for the responses and pics. ill be in NC this weekend for orientation at college then the weekend after that im hopin to get it in.
if you can find the money? you can always change your kit cage a little to make it work for you.
good luck on the build.
