Gears & Axles - I will never buy another set
View Full Version : I will never buy another set
HumpinSS
10-27-2003, 08:11 PM
of Richmond gears again
http://www.ls1camaro.net/freehosting/IMG_0047.JPG
http://www.ls1camaro.net/freehosting/IMG_0048.JPG
http://www.ls1camaro.net/freehosting/IMG_0049.JPG
trackbird
10-27-2003, 10:54 PM
10 bolt gears?
benpimpin1
10-28-2003, 06:30 AM
i have never seen a set of gears do that because they were defective, who installed them?
Brains
10-28-2003, 06:40 AM
Looks just like my Richmond 4.10's when I broke 'em on a 4500 RPM ET-Street 3700lb. dump ... That was my 7.50 1/8th mile run :D
HumpinSS
10-28-2003, 08:39 AM
My father installed them using a pinion depth tool
trackbird
10-29-2003, 09:21 PM
It is still a 10 bolt. I'm not sure the gears are at fault here. Richmond states that the 10 bolt is only good for 400 hp max and that traction and "clutch dumps" will keep it from going that far....
If you drive it like you are trying to break it....you will....
Or,
That's racin'
wrencher
10-29-2003, 09:43 PM
The pinion on a 10 bolt/4.10 gets so small their doomed to fail.
Slowhawk
10-29-2003, 10:05 PM
Agree'd ;)
4.10 gears in a 10 bolt are tiny... Any gear set can do that.
