I hate my F***king Car!!! Damn Clutch
well its another clutch master cylinder problem!! im honestley sick of trying to figure it out! ive replaced EVERYTHING and i still have issues infact its actually worse! anyways enough of my venting.
I replaced my clucth with a centerforce dual friction 12'', resurfaced flywheel, new slave, new TOB, new pilot bearing, and new master cylinder OE replacement from napa. anyway my new master sits about 1/2'' under my brake pedal. my old one sat even but it engaged probably 1/2'' to an 1'' off the floor which was weird so i figuered it was the faulty 2000 master cylinder.
anyway i replaced it and now it engages on the floor and ive bleed it probably 15 times. Its very hard to get it in and out of gear.
after my clutch install i started to get a grinding noise when i pushed the clutch pedal in but as soon as i let it out it went away so i figured i was having disengagment issues. so i replaced the master today and i end up worse off. what can i do?
sorry about the long post i've just spent so much time trying to get my car the way its supposed to be and i'm really fed up with it! if there's any other info i can provide i will be happy to.
I don't think it's the clutch though I guess it could be? But it did this ever snce I bought the car which was two years ago n it was completly stock I think it's the master. Does the stock clutch require a shim?
I am 99% that you need to get an adjustable master cylinder. I used ram now I can shift at 6200 rpms all day long. No probs shifting this will help you. Then go thru all the proper steps bleeding etc.
Well I'll buy a adj master then... N I have bleed it with a mityvac multiple time.do you guys think the ram adj is a good buy. I only ask because I am a college student that's on a budget and the tick is pretty spendy for me.
look is the FS section for a used one. i currently run a used RAM that i got for a decent price
read this its helping me alot i just dropped my tranny again after putting in a new clutch cuz i didnt know about the shim thing. also on your bearing on the slave take the spring and the bearing off the slave an look inside the slave. u will see a shim thats 1"3/4 outside diamiter by 1"3/8 inside diameter. this always gets forgoten about. do some measureing and ull get it. it take awhile to understand well not really but just read and read and read till u understand it. maybe thats ur prob.
https://ls1tech.com/forums/manual-tr...need-shim.html
