500rwh h/c 346 guys please come in
Old 05-21-2009, 11:46 AM
WANTSUM411's Avatar
Default 500rwh h/c 346 guys please come in
I amlooking to do a n/a 346 with 500rwh.what set ups are proven ?just wanta do rod bolts & leave all else stock,will this work?i am runing ms3/stg 2.5 5.3's fast 92/92 now.it would be nice to have a lil more low end.loong for proven combos.thanks!
Old 05-21-2009, 01:15 PM
teke184's Avatar
to make that kind of power peak, you're sacrificing power down low.
so what you're asking is kind of an oxymoron.
i guess bigger cam and better heads is what you need.
Old 05-21-2009, 01:48 PM
WANTSUM411's Avatar
This is why i posted to find out wh is proven t work.what it take is what it takes.just looking for some set up details & info.
Old 05-21-2009, 01:53 PM
jaber911's Avatar
https://ls1tech.com/forums/generatio...heads-cam.html
Old 05-21-2009, 01:56 PM
ajw2500hd's Avatar
Well what did it dyno at now!?!?!
Old 05-21-2009, 02:11 PM
CARTEK Racing
WS6TransAm01's Avatar
Here is the dyno for my CARTEK 4X setup, just like you want, stock 2001 ls1 bottom end with ARP Rod-Bolts, QTP 1-3/4" headers, TSP 3" Drue Duals, Fast 90/90, 42# injectors, EWP, 85mm lid & K&N
And unlike a lot of other "500 hp" H/C setups, this one has proven track results as well as a dyno sheet
Old 05-21-2009, 05:09 PM
chrs1313's Avatar
yup
Old 05-21-2009, 05:23 PM
s1ck s0n's Avatar
mine is making 480hp with a t-rex cam and ported ls6 heads, fast 90, nw 90 tb, kooks 1 3/4 headers, etc...
Old 05-21-2009, 05:27 PM
cellulis44's Avatar
its doable without losing ALL of the low end.. but you need enough rpm to make the 346cubes efficient enough to move that much air.
a perfect set of heads and a good intake is a good starting place.
Old 05-21-2009, 05:29 PM
miami993c297's Avatar
Take time to read my thread below...some good info:
https://ls1tech.com/forums/dynamomet...1rwhp-fti.html
Christian
Old 05-21-2009, 06:35 PM
SOMbitch's Avatar
Who ported your LS6's?
Look at Christians setup. That is a sick N/A streetcar. Damn I wish I had snapped up that set of used ETP's when I had a chance
Old 05-21-2009, 09:16 PM
wantsum410's Avatar
Talking 500rwh
THANKS FOR ALL YOUR INFO!!!!WS6 TRANS AM I HAVE YOUR UTUBE VIDEO MARKED AS A FAVORITE, WATCHING YOUR CAR LEAVE IS SOOOO GOOD.ESPECIALLY THE SLOW MO WHEELS UP LAUNCH!JABER 9 I RAN ACROSS 1 OF YOUR POSTS THE OTHER NIGHT & WAS TRYING TO GET BACK TO IT JUST TODAY THAT IS ONE FINE T/A.I AM RUNNING MY SET UP IS IN A '72 SS CAMARO.13/4 MACS INTO 3" DR. GAS X INTO 3" 2 CHAMBER FLOWS WITH TURN DOWNS.CAR PUT 430 RWH AT THUNDER RACING WITH LS6 INTAKE T/R PORTED T/B.I HAVE SINCE ADDED A MEZZIER ELEC. WATER PUMP,FAST 92/92.AT TUNING SCHOOL IN DALLAS CAR PUT 432RWH WITH THE AD ONS PEGGING 109% INJ DUTY CYCLE.EVERYTHING I RESEARCHED SHOWED I SHOULD HAVE PICKED 25 TO 30 HP AT WHEELS WITH THE FAST 92/92.BOB TELLS ME I SHOULD EXPECT AN EASY 25HP PICK UP WITH BIGGER INJ A RETUNE & MORE TIMING .LOOKING TO UPGRADE HEADERS TO 1 3/4" STEPPED TO A 1 7/8" FROM BREWER REST.NOT ALOT OF CONV PARTS TO CHOOSE FROM FOR A 2ND GEN LS1.I JUST PUT IN MY NEW 42# GREEN TOPS & GONNA RETUNE.CAR HAS BEEN 11.53AT 118 WITH A 1.63 60'.ITS HARD TO COMPLAIN ABOUT THAT WHEN I DROVE IT DALLAS WITH 4:11'S & PULLED 25MPG AT 75MPH.YOU JUST DID NOT DO THAT WITH OLD SCHOOL CARB STUFF !!THANKS FOR ALL YOUR INFO IT WAS REALLY HELPFULL.
