Sudden Loss of 4th Gear
So, Long story short, My 4th Gear disappeared right after I had my Transmission Tuned at Speed Inc. Speed Inc wouldn't give me so much as a refund and pretty much told me to **** off for thinking they had something to do with it. There was nothing I did to make my freshly rebuilt Trans lose 4th.
Anyways, I've been doing some research about it, and the only thing I could come up with is the 2-4 band is slipping and and that the servo seals may be bad. I already replaced all of my 3-4 clutchpacks, and replaced the 1-2 shift solenoid about a month ago.
Should I upgrade to a Corvette Servo and see if that fixes that? Can I swap out the servos or 2-4 band with the trans in the car or no?
Thanks guys,
MAYH3M
Thanks guys,
MAYH3M
LS1Tech Sponsor
You already have the corvette servo.
Since you have second the band most likley is ok. I would look at the 4th servo.
It is unlikley that tuning caused and issue of this type.
I would however use a scanner to verify that the command is being given.
Also are you sure its 4th your missing and not lockup
__________________
Yeah, the computer is commanding 4th, it's just not shifting into 4th Gear.
and, I already have a corvette servo? I never upgraded it, unless Corvette Servo's come in all 4L60E's.
Thanks
Thanks
