Drag Racing Tech
What ET gains could I have going from Bilstein HD shocks to QA1's in front?
Old 05-24-2009, 08:02 AM
Vetal's Avatar
Default What ET gains could I have going from Bilstein HD shocks to QA1's in front?
For now my 60ft are somewhere in 2.0 range, with 340whp 13.0@110mph.
Will front QA1's help me much or just 0.1 in 1/4? I know they wouldn't hurt, just not sure it will be cost-effective upgrade now when I'm very on budget...
Now I have Bilstein HD's with WS6 springs on all corners.
Or maybe just some stockers on the front would help too?
Old 05-24-2009, 08:25 AM
ndfrsd6's Avatar
they will transfer the weight quicker so yes they will help.....you should go 1.8's with no problem and are you on a drag radial ....the drag radial is a must also though and every .1 down low in the 60 is good for .2 on the top
Old 05-24-2009, 11:44 AM
Race your car!
JL ws-6's Avatar
qa1 shock should help, swapping to a 300 lb spring will help weight transfer too.
If you have a stick car, the R series may be a better route because the compression remains on a rate about equeal to what setting #8 is on the regular 12 way, which will help stop the nose from dropping so much during shifts, and should help keep the radial tires planted rather then unloading.
If you have an auto car the regular 12 way will be fine.
Old 05-24-2009, 05:15 PM
Vetal's Avatar
Sorry forgot to tell... It's M6, running ET Streets 26x10.5-R16
Old 05-26-2009, 05:35 PM
Vetal's Avatar
So, what could I gain? like .05s, or more like .2s?
Old 06-01-2009, 05:26 PM
Vetal's Avatar
Anyone?
Old 06-01-2009, 06:26 PM
andy670ho's Avatar
Are you spinning? If not you are probably not going to see much if any gain, I went 1.49 60 ft. on stock shocks with MT Drag radials.
Old 06-10-2009, 03:47 AM
Vetal's Avatar
I'm probably spinning because I have 2.0 60ft... Also I don't even have stock, I have Bilstein HD shocks...
Old 06-10-2009, 11:34 AM
AChotrod's Avatar
I think you could gain .5 on a nice 5k dump. If the car hooks 1.6 or 1.7 is possible wich is a ton on the big end. Yes its worth it and one of the very next mods to my car.
Quick Reply: What ET gains could I have going from Bilstein HD shocks to QA1's in front?
