Getting worried as hell!!! help
Hey guys, I have a 00 ls1 Z i'm at 79k miles. I don't have much mechanical knowledge, but i read up a lot. But this problem i have no answer for. I have been driving my car around for about a week and every single time i cut my car off and cut it on, at some point, it starts to sputter (as in shaking as if it's about to stall). Some times it's minor, some times it's terrible. When it's minor, it can be heard in the exhaust. When it's major, it shakes bad to where if you were looking at me drive by, you could see the shaking. I do have a pressure plate that is getting ready to give in. But that shouldn't make all of this trouble would it? The shaking has been convenient to the 8 straight days of storming rain that i had to drive through. Is there any way water may have gotten into the block? I have a leaking power steering tube or pump or something, I fill up the resevoir, and before i get home, it's empty and my car starts winding hard every time i make a sharp turn, or park. Can this be affiliated? Thanks ahead for any help.
Your pump and the "sputtering" problem are unrelated. You said its raining so I would look at the wires going to the O2 sensors and also check for codes. Sounds like they are getting wet and reading wrong and throwing the pcm off. Do a search and I am sure you will get a little me in dept explanation.
yeah, when i get in lets say to go to the store, it will hesitate initially for maybe a mile or so, and eventually work itself out. but after I go to the store and come back out and cut my car on, it will start the process over again.
i can't believe i missed that part. there is a sensor hanging under my y like where my cats used to be (i have the off road y-pipe) I figured it's been like that forever. that may be an issue.
it's sort of hard to diagnose because i have been getting these 02 codes on my diablo since i got my headers and cam. I'm untuned. but 2 of my o2's are going bad. Does 02's give these kind of results when failing?
lol, point taken. i wish my car would be patient. i'm enlisting soon and will get a bonus... i want to do a procharged set-up and will be needing another tune when i'm done, but if it will keep this car from embarrassing me at a light... so be it. Thanks so much guys
actually, no to both. i have no cats or mufflers. I don't have aftermarket heads, just headers and cam. no sims. just stockers that have been throwing codes for over a year. I didn't know they needed to be replaced. i thought it was a false reading due to the fact that i was running catless.
you did a cam and headers without tune? I missed the cam part.
I would look at the wiring if its hanging and see whats up. Doesnt hurt to check it out and you might find something.
Then get it scanned and the codes read and fix the issues and then get it tuned. Same time would be good.
You can run simms or tune out the rear sensors.
check all you fluids to see if anything is getting sucked into the cylinders; when my head gasket went my motor was chugging coolant and shaking like ****.
could be a bad plug or bad wire.
could be a bad o2 sensor.
check your air filter; could be clogged and impeding the flow of air
do you have a white or blue colored steam coming from the exhaust?
i have had white/ blueish smoke since a month after buying my car in 07. I have a ring leak so oil passes through. I do have a leak with my power steering, and there was quite a bit of greasy residue around the radiator as if it sludged around in the engine bay. I think the tune is a way to go once i get this issue fixed. My 02's have been throwing codes for a LONG time, so i'm guessing it's finally starting to catch up with me. There's no use in changing the 2 in the back if i'm tuning them out right? Those are the bank 2 sensors right?
