head gasket?
i went with cometics. i think they're some of the best and some say reusable .... have a lot of different thicknesses also. also no cleaning if you take them off like the stock graphite mess.
If you aren't having the block resurfaced then GM MLS is more forgiving to imperfections. The cometics require a flat surface and specify an RMS range for the machined deck finish. Most people use them without issue, but a few have had sealing problems. With your cam you really don't need a large bump in compression to achieve optimum results, so I say mill the heads to 59cc and run the GM MLS.
