CSR Flexplate
CSR Flexplate
Started the motor up first time w/ CSR's new flexplate. The bolt heads on the plate were hitting the starter housing. Had to pull the starter off and grind down the housing to get the flexplate to clear.
Just a heads up.
Just a heads up.
LS1Tech Sponsor
Talked to csr today as we have had 3 people with the same problem. Send them back and we will either refund your money or install a new shorter bolt.
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
LS1Tech Sponsor
Let me know
Greg
Greg
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
what was the result of the issue? im getting ready to go take my starter off for the same reason.
Does the converter push any? if so ill have to grind on the factory starter housing a little. ill post a picture up later.
