Single or double springs for a street car
I'm ordering heads today but have a couple of questions. The cam I will be using is .580 lift and I just put .600 rated bee-hives on my stock heads. The new heads will have .650 rated double springs which may/may not clear my 1.85 rockers. As an option I can knock off $200 and get the heads without springs... install my bee-hives on the new heads. Would their be any benefit to the higher rated springs given my lift or to the bee-hives maybe being easier on the valvetrain? Just curious also those guys running >.600 lift daily or lots of mileage how you are making out with doubles.
.600 rated. Scoggin said not much over .600 when I asked him about them. I'm at .580
http://www.sdpc2000.com/product/SDL1...S1Setof16.aspx
Duals are always better than single springs..very seldom do both inner and outer springs break at the same time...keeps a valve from dropping and causing a expensive repair...those dual springs should clear your rockers..the comp 918 spring has had numerous bad batches of springs and I would choose a different beehive spring than the comp 918 if you feel that is what you want...PAC has a good beehive spring..
1 Post
The dual spring setup should last a long time on the .581 lift. Less maintenance just install and forget them. I bet you'll still be running the same dual springs 5 years from now without a care in the world. Good luck.
No hijack attempt here, but are there any inherent advantages to keeping a good quality single beehive spring over a dual?
I.E., will a single beehive spring allow a higher rev (valvetrain weight) over a dual? Not to be a lightweight here, but are dual springs noisier than singles?
OP, hope you do not mind the additional clarification and question added.
Thanks.
..WeathermanShawn..
Thanks.
..WeathermanShawn..
The Beehive designed spring combined with the Ti retainers will provide more valvetrain stability due to the overall weight factor,thus allowing for quicker revs and a higher rpm capability.At 581 lift the best bang for the buck and overall performance is the beehive springs hands down, and don't tell me otherwise...this is based on experience with this very cam!!!
Typical lobe lift of a cam is in the .300-.380" ballpark.
It seems you are basing this on the "advertised lift" which assumes 1.7 rockers will be used.
With 1.85 ratio rockers, you are now looking at .631" actual lift.
Only beehives I know of that will handle that would be the PAC 1518s.
