which valve springs
has anyone ever used scoggin dickeysvalve spring kit ? if so what do yall think about it? would that be good for my set up??
http://www.sdpc2000.com/cart.asp?act...art&catid=2270
SN95 Director
The Crane duals are a drop in spring, no machining.
I'd say no matter what, go with a dual spring and stay away from the singles. There's another post befoer this one where a guy used those Comp 918's and the spring broke, wreaking havoc in the engine. With a dual spring you're almost always gonna have one spring to keep the valve up and save the motor from serious damage if you have a spring break. Plus, the duals have better harmonics for sustained RPM's and longevity.
There will be a couple of new valve springs introduced for the LS1/LS6 applications at the PRI show in December. A drop-in 1.260" made from ultra clean chrome silicon. Also a 1.480" spring for the high lift stuff. These engines will also benefit from the restrictor pushrod which helps in maintaining proper valve pressure in the lifter and promotes higher rpm.
Cstraub
Cstraub
