150k maintaince
Old 07-12-2009, 09:48 PM
crazymofo1986's Avatar
Default 150k maintaince
what things suspension would be bad at 150k. shocks but wont relize how bad they are untill i put new ones on. ball joints. what other bushings? should everything be changed to moog?
Old 07-13-2009, 02:26 AM
infinitebird's Avatar
I have 190k and just replaced all my bushings, ball joints, and tie rod ends with moog stuff.
Was a VERY noticeable improvement.
Also might want to check trans and motor mounts.
Old 07-13-2009, 04:38 AM
ineedamotor's Avatar
moog is nice stuff.. i wouldnt hesatate on there stuff..
Old 07-13-2009, 04:35 PM
slow's Avatar
mook rear lca bushings here, work great, and got rid of the loose feeling and clanking I had in the rear end.
Ryan
Old 07-13-2009, 08:45 PM
what bushings. plan on getin lca so i wont need those bushings. what others. inner tie rod ends should be fine i only need outer right.? and from what i hear i dont need upper ball joint? only lower
Old 07-15-2009, 12:29 AM
m6camaro's Avatar
TTT. I am looking to freshen up my front suspension as well. What generally needs to be replaced?
Old 07-15-2009, 01:31 AM
68Goatboy's Avatar
i would like to know as well
at 158K miles on the clock i can tell that some things need a little tlc
Old 07-15-2009, 04:04 AM
KILLER-LS1's Avatar
go with energy suspension, they make a whole kit, I have it and i love it!!!
Old 07-15-2009, 07:34 AM
UMI Sales's Avatar
Default A suggestion for you that will save time and not be a hassle!
Hello
I noticed that you are interested in a suspension upgrade! And I just wanted to leave you know that If you are looking to get better performance out of your vehicle. I would suggest just replace the rear lower control arms and pan hard bar seeing how they are just a stamped factory piece. UMI Performance offers a few different versions of rear end suspension kits. They all feature Energy Suspension and are grease able. Below is a link to show you what all we have to offer.
http://www.umiperformance.com/catalo...db38mtnrv8q520
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
