whats the weight difference between a spooled 12 bolt and stock 10bolt?
I just took my 12 bolt out and replaced it with a stock 10 bolt (demodding to sell.) I should have weighed them. My back tells me the 12 is significantly more . I'm curious about this as well.
If someone knows stock 10 weight I can weigh my 12 bolt, it has the Eaton posi but that probably doesn't change it too much.
i can let you know in about 2 weeks...dont have the 12 bolt yet...even if the overall weight is heavier i bet you gain some back with the rotating weight of the aluminum spool, and in my case shortened 2" axles and light weight ring gear...
or at least i hope...
How did you get a stock internal to trap 116?
thinking of 5.5 backspace billet specialties, they run like 240 each but I am not liking the 16lb weight…still undecided might just keep the convos for the front and get new rears…I haven’t ran the math yet but I think I am going to be short of gear with 4.10s and 26”, can anyone show me the calculator, so 28” drag radials will be in order…
Choose your bolt ons well, get a good tire and converter, and wait for some good air...it would trap 114-115 or an average 0 to +1000 DA day...
on these runs it had the smaller ss3600 and hit the limiter a couple times...it had 11.3s in it...
http://www.converter.cc/testimonials...deo/index.html
i've hit 109mph on my bolt on only LT1 and im not even full bolt ons yet
My 10bolt was 149 IIRC, (stock 342 01') no rotors, but backing plates, Ebrake shoes. Check the thread I made about my S60 when I got it I weight them both and listed some parts weights. S60 was 196 I remember with the same parts on it. (373 truetrac, witch is heavy)
when i was SI went 114 with stock manifolds/and exhaust , just cats removed with 2.25
pipe.
pipe.
pipe.
pipe.
headers are overrated when SI...if i was going sleeper that would be the route i would go...that car doesnt even have headers how fast can it be...
