Reverse Lockout Switch?????
Old 08-02-2009, 05:09 PM
charlie c5's Avatar
Default Reverse Lockout Switch?????
I just installed a new clutch from Monster, new flywheel. Everything is new. I bled the clutch pretty well. But I CANT get into reverse. Wont go at all. And its pretty tough to get into any other gear. Is this the reverse lockout acting up. Please help guys.
Charlie
Old 08-02-2009, 06:59 PM
charlie c5's Avatar
I just went out and checked all of the "Under the hood" fuese. They were all fine. I tried with the car off. Andcrazy enough, I CAN get it into reverse, with the car off. But then I crank it up and nothing. Wont go into reverse, and its pretty tough to get into all of the other gears.
Old 08-03-2009, 12:37 AM
KILLER-LS1's Avatar
if you really need to back it up, you can force the lever past the lockout thingy, just push really hard. check the connector going to the RLS
Old 08-03-2009, 07:46 AM
the_merv's Avatar
Did you plug the CAGS Connector into the Rev. Lockout?
Old 08-03-2009, 08:09 AM
Mike454SS's Avatar
It sounds to me like your clutch isn't releasing properly...reverse will usually be the hardest gear to get into when the clutch isn't fully released.
If you can get the shfiter into the reverse gate, just all the way to the right but not even trying to push forward yet, then it's not the reverse lockout. The lockout solenoid only prevents you from getting past the 5/6 gate to where the reverse gate is...once you're over in that gate, it doesn't prevent you from pushing forward into reverse...if thats where the difficulty lies...the problem is the clutch/clutch hydraulics.
Old 08-03-2009, 09:22 AM
charlie c5's Avatar
Im a little ignorant. But whats the CAGS Connector.
Old 08-03-2009, 10:24 AM
the_merv's Avatar
It blocks 2nd and 3rd out if you get above a certian RPM in 1st Gear..makes you go to 4th. It's in the same area as the Rev. Lockout..very easy to get them swapped.
It's and idea to run with..don't know for sure.
Old 08-03-2009, 10:49 PM
charlie c5's Avatar
Hows this for crazy. just for the hell of It I tried to put the car into reverse with the car OFF. and it went. right in. what the hell....
Old 08-04-2009, 06:26 AM
calhoon's Avatar
That pretty much says the clutch is dragging.
Old 08-04-2009, 07:16 AM
the_merv's Avatar
Was the Key on when you got it into Reverse with the car off?
Old 08-04-2009, 09:13 AM
charlie c5's Avatar
Dragging???? No, this thing is brand new. I sure hope not...
Old 08-04-2009, 09:14 AM
charlie c5's Avatar
No, I have the key out of the ignition when I get it into reverse...
Old 08-04-2009, 04:18 PM
charlie c5's Avatar
Ok, update time. I checked all of the connectors on the tranny. Any they are all good. And just like I thought, non of the connectors are interchangable. Damn, what now.?
Old 08-04-2009, 04:37 PM
crainholio's Avatar
Re-bleed the clutch. It's important to open the bleeder while the clutch pedal is being depressed...not just push the pedal down and then crack the bleeder.
You move fluid (and air bubbles) doing it the right way, and get results much faster.
Also, stick with cheap regular DOT-3 fluid. Plenty of people have had issues with certain synthetic brake fluids, including me.
Let us know how it goes.
Old 08-05-2009, 11:19 PM
charlie c5's Avatar
Ok, so I have a date with the local tranny. Tranny SHOP that is. They are gonna use some sort of pressuring system, and force the fluid in and air out. I told them to BE CAREFUL and not to blow my seals..
Old 08-06-2009, 08:32 PM
1nastyss's Avatar
Keep us up with any updates, im having about the same problem since we put my tranny back in, does yours shift fine while driving ?
Old 08-06-2009, 09:46 PM
charlie c5's Avatar
I dont wanna say it shifts perfectly, but it does shift. The ONLY thing I did was replace the clutch, and threw a new motor in. The tranny performed flawlessly before.
Old 08-08-2009, 12:08 PM
Chris05ssTruck's Avatar
Yea....sounds like it has air in the system.
Old 08-08-2009, 11:17 PM
charlie c5's Avatar
Ok, Ive bled and bled. I have an appointment with a tranny shop on Monday. They said they have some sort of pressure bleeding system. But, listen to this. I was under the car checking all of the connections and noticed that the part of the slave that the hydrolic line snaps in to wobbles. Is that normal.?? I dont see any fluid leaking on the ground. I just didnt think that should move at all...
Old 08-18-2009, 10:21 PM
charlie c5's Avatar
Holy crap, after stressing and just about tearing my tranny out. Come to find out the issue was the slave needed to be bled more. Thanks for all of your help guys.
Quick Reply: Reverse Lockout Switch?????
