Need Help... Same broken Spring AGAIN..!!
Its been the 3rd time I broke my valve spring... The scarry part is that i keep on braking the same one..!! I really dont know what it is ... I want to know if anyone knows what it might be..!! Before i start taking more **** apart..!! am not sure of the brand but i got the silver dual springs supposably rated to .650 of a lift....
what type of retainers... floating valve can beat up a titanium retainer quickly... when you remove the valve spring assembly, check the underside of the retainer face for excessive wear...may be an issue where the retainer is not allowing the valve spring to rotate in the spring cup, and harmonics are beating it to death..
could also be a worn valve guide allowing the valve to rock. but usually if that is the case the valve wont have a good seal on the seat..
O.K Guys I have my **** taken apart..... I checked for Push rods, Rocker arms, retainers look good and locks..... My valve stem is not bent but... Theres this blue i would say it looks like an o rig that goes around the botom of valve stem stretch out... wont go back in place...!! maybe a seal.....? ?? idk.. wouldnt think how that would get me a broken spring... but who knows..
Am starting to think it might be a lifter or something..... wouldnt know untill i pull the head off..!!
It happens everytime i **** arround and give it high rpm afther 2 or 3 good pulls... then am driving normal and in a day or two my car starts missfiring... i take the vale cover off and the same broken spring..!!
Do you guys think it might be a lobe on the cam..???
Hey gilbert I dont think is the springs.... I keep braking the same spring over and over.. I think if i put a dual gold spring or anything else... watever i replace it with ill still barake it..!! i think is something with the valve or a lifter....??
Na.... That was the 1st time(passanger side) i ever broke a stock spring with the stock cam...
but know is the other side..(drivers side).....
I know.... I dont want to have to pulled the head off.. so i might just replace it one more time.... and not rece the motor again... baby it... till i get some money... to fix it right... u know find out the real problem..!! by a new gasket re-sufrace the head... ect...
