question bout mounting a procharger on a iron block
Old 09-04-2009, 09:25 PM
Taubr Unit's Avatar
Default question bout mounting a procharger on a iron block
The kit i got uses a stock style ls1 alternator to mount the alternator lower drivers side. Then routed around to the stock tensioners etc. Now a iron block doesnt have the block threaded in that one spot where one of the bolt goes (so u cant use the BMR alternator bracket). I want to buy a race EWP and run just a short belt to the balancer but i wouldnt be able to tension it. Then to top it all off the procharger bracket uses that that hole on the block to mount the brackets. Who here drilled/tapped there iron block to mount this stuff? Or what did you do?
Old 09-05-2009, 01:21 AM
SilverSS's Avatar
Drill and tap that hole/tab then do what this guy did for the other missing boss. I made something similar like this but used steel stock from H-Depot. Can't tell you how good it works yet since I haven't fired up the F1A.
https://ls1tech.com/forums/forced-in...t-bracket.html
Old 09-05-2009, 11:19 AM
LS1RedZ's Avatar
I forgot what thread size the stand off is. Just drill and tap it. Thats what I did to mine. It was fairly easy.
Old 09-05-2009, 12:31 PM
Taubr Unit's Avatar
yea, im gonna have to. Just worried about making the hole straight in and not on a angle. Damn this crap
Old 09-05-2009, 12:59 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I had the machine shop drill & tap that hole when they were boring the cylinders and surfacing the deck of my LQ4 block.
Old 09-05-2009, 01:03 PM
Taubr Unit's Avatar
wanna trade me blocks?!?!?
Old 09-05-2009, 01:08 PM
ChevyChad's Avatar
I'm sure it would be a lot easier for you to just drill and tap yours man
Old 09-05-2009, 01:13 PM
Taubr Unit's Avatar
yea ure prob right
Old 09-05-2009, 05:26 PM
Taubr Unit's Avatar
so **** it now. Sacked up and got it drilled n tapped!! It was pretty nerve racking but it all went pretty mint so im hyped now.
Quick Reply: question bout mounting a procharger on a iron block
