Western Members CA, AZ, NV, UT, CO, NM, HI
People with t56s...
Old 09-18-2009, 04:09 PM
1Loudz28's Avatar
Default People with t56s...
do your transmissions get hot after about 30 mins of driving? and i mean hot to the point you can feel the heat through the shift ****?
if not, what fluid are you guys running?
Old 09-18-2009, 04:30 PM
Banned Village Idiot
LS1BLKSS's Avatar
yep not hott hott but you can feel the heat from it
Old 09-18-2009, 04:54 PM
Datzneat's Avatar
After about 3hrs of straight driving mine will start to get warm. Stock fluids.
Old 09-18-2009, 04:56 PM
1Loudz28's Avatar
im askin cuz i just switched to valvoline atf dex3 from chevron dex3 and i swear my trans has been getting hotter with the valvoline. guess its time to switch back
Old 09-18-2009, 04:59 PM
llorracs93s10's Avatar
I feel the heat from mine, but i was told it aint no biggie. It will suit me good in the wnter time, lol
Old 09-18-2009, 05:12 PM
1Loudz28's Avatar
yeah, im used to a little heat, but i just noticed today driving to work that my shift **** was HOT. lol
Old 09-18-2009, 05:20 PM
letsrun97z's Avatar
Heated shift **** will be perfect for this winter!
Old 09-18-2009, 05:42 PM
ss.slp.ls1's Avatar
I have two cars with T56 transmissions. One that I've put over 100k miles on myself. I have never noticed any heat from either. I use Valvoline MaxLife dex/merc in both cars.
Old 09-18-2009, 06:01 PM
1Loudz28's Avatar
hmmm. fawk. what causes the tranny to heat up, its brand new fluid and it was filled with 4 quarts
Old 09-18-2009, 06:03 PM
ss.slp.ls1's Avatar
Maybe your vent tube is clogged...(shot in the dark)
Old 09-18-2009, 06:15 PM
1Loudz28's Avatar
wheres that located on the trans and how can i check it?
Old 09-18-2009, 06:18 PM
ss.slp.ls1's Avatar
The black hose on top.
Old 09-18-2009, 06:22 PM
1Loudz28's Avatar
thanks!...any trick to checking it?
Old 09-18-2009, 06:23 PM
ss.slp.ls1's Avatar
Pull it off and blow through it, lol.
Old 09-18-2009, 06:25 PM
1Loudz28's Avatar
dope LOL. thanks for the help
Old 09-18-2009, 06:37 PM
lilpb1's Avatar
This **** made me laugh.
Old 09-18-2009, 07:36 PM
MrElectric03's Avatar
Havent noticed it through the shift ****...ofcourse it gets hot though. I run Royal Purple in mine.
Old 09-18-2009, 08:18 PM
LS1_Fonzie's Avatar
I'm driving mine without the shift boot because I broke it when I installed the new shifter. It gets hot for sure, but nothing unbearable. I'm using whatever ATF fluid recommended from the factory that I put in around 10k miles ago.
Old 09-18-2009, 10:27 PM
tripblackls1's Avatar
i dont get heat from my shift **** but of coarse i do from the shift stick
which is normal with aftermarket shifts and stick,
btw the fluid is not really a big deal and i highly doubt it caused any heat increase
the only time ive seen fluid choice resulting with problems is when running synthetic or royal purple(worst thing for a t56)
myself i preference two quarts of dex/mer and then two quarts of type f
Old 09-18-2009, 11:34 PM
DarkKnightRider's Avatar
I'm an auto guy but I always thought the syncromesh was better for these trannys.
Quick Reply: People with t56s...
