reverse flow stock fans?
I didnt know where to post this question, but since i am doing something related to FI i thought i would post in here.
Can you switch the polarity of your stock fans and put them as pusher setup?
No I moved one in front of the A/C condenser and reversed the wired to make it a pusher ... the other is still a puller on the other half of the radiator. Not in a sandwich formation, that's not good, air will get trapped and stay hot.
. . . _ _
. [ / / / / Engine on this side
. /_/ /_/ ] <~~Fan/ puller
. A/C Rad.
if that makes sense.
. . . _ _
. A/C Rad.
. . . _ _
. A/C Rad.
. . . _ _
. A/C Rad.
Restricted User
I am going to try using them both as pushers.... but i tried it out befor install and they push about 1/2 reversed as normall... Setup wont be done for a while but ill keep updated!
Restricted User
forgot to post my results of using the stock fans.... ya it didn't work...
but check the link in my sig.... I got a 16" fan that works awesome for like $50 from "Hot Rods USA" on ebay
