Compression vs CFM ??
Old 10-18-2009, 12:44 AM
ls1camaro98's Avatar
Default Compression vs CFM ??
what would be better off a higher compression and less flow or less compression and better flow. example- lq4 stock bottom with 243 heads has a more compression but less flow or a lq4 stock bottom end with l92 heads less compression but better flow which combination will work best..
Old 10-18-2009, 12:54 AM
stevied916's Avatar
mill the heads if you want to keep compression. It's around 60-70 to mill the set
Old 10-18-2009, 12:57 AM
i know you can mill the heads to gain compression. im asking what is prefered in building a motor more compression or more cfm??
Old 10-18-2009, 03:54 AM
PREDATOR-Z's Avatar
Actualy, both
It really depands what you are trying to achieve. A 10:1 LQ4/L92 with small duration/high lift cam (.600 or so) would do real well as all around street performer.
But if you are going for big numbers, right size cam and compression will surely surpass it.
Old 10-18-2009, 11:12 AM
hammertime's Avatar
The application makes a big difference here. Those L92 heads can move a lot of air, but they have some large ports, and resulting lower velocity on the same size engine. Adding 243 heads to a mild-medium 6.0 is a great way to improve power and drivability. If you are after big numbers, airflow will take you there, but you need to be sure that you create the right combination of parts to get there. Big ports and a big cam make for great top end performance with less than stellar results down low, especially if the compression is lower to boot.
Old 10-18-2009, 03:54 PM
well im trying to get a 3100lb mustang into the 10.50 range on motor. you help me decide what to do.
Old 10-19-2009, 12:42 AM
hammertime's Avatar
If it's a track only car, then your gears and converter will take care of any problems on the low end. A good breathing setup that makes power from 4000 - 7000 rpms is perfect for that. If you are building a street/strip car, then your mix of driving will ultimately decide for you. The more time you plan to spend on the road when you are not pushing the car full tilt, the more you should lean towards velocity and streetable power.
Assuming the suspension and gearing are optimal, you're looking for 480-500 flywheel HP. That is certainly achievable with either head.
Old 10-19-2009, 12:49 AM
you think 480 -500 flywheel horsepower will get a car going 10.50's that weighs 3100lbs. the car will be driven on the street to and from tracks. it is no means a daily driver more like a weekend warrior or whenever i feel like taking a cruise with it.
Old 10-19-2009, 03:17 AM
SweetS10V8's Avatar
CFM - Air in and air out = power. You can have all the cam and compression in the world and its not going to help if you dont have the ablilty to flow air (see sig).
Compression and cam are important also, just not as important as heads because with better heads, you get a better cam. Its about making a grea combination that makes a great running engine.
I just went through this exercise myself. I have an LQ9, with Lingenfelter CNC L92/LS3 heads. I went with a Comp LSR cam 219/235 .607/.621 113+5. Its their LS3 (single bolt) cam, and I had them grind it on a three bolt core for me.
It pulls like a freight train and is extremely drivable, and Im still learning to tune driveability, so its getting better and better on the drivability side.
Note: I milled my heads .030 and this cam is about as big as I could go, even though I wouldnt have gone any bigger. My piston to valve clearance was about .070"s on the intake and .080"s on the exhaust. All my buddys talked me out of the 215/223 .604/.614 LSR cam that I originally wanted.
Old 10-19-2009, 06:14 PM
no one has given me a direct on which heads would be better to use. the 317 or the 243's they flow the same numbers but the chambers in the 243's are smaller which will make more compression. im guessing these are the better of the two.
Old 10-19-2009, 07:13 PM
SweetS10V8's Avatar
From what I understand, the #317s and the #243s have the same ports. So the #243s will make a little more power because of the small combustion chamber giving you more compression.
Old 10-19-2009, 07:29 PM
thanks guess i will be going with the 243 heads...
Old 10-19-2009, 09:00 PM
Paul57's Avatar
The flow data I have seen shows the 317's flowing slightly more on the intake than the 243...while the 243's flow slightly more on the exhaust than the 317's. The numbers weren't significantly different...both have the same port and valve size.
Old 10-19-2009, 10:33 PM
hammertime's Avatar
I checked around and the calculator I used was pretty conservative. Looks more like 530-550. Apologies for the error.
This is why I was hesitant to suggest these heads for the smallest street driven engine that they will fit. Heavy hitters and L92 heads
Originally Posted by Slowhawk
The reason we stay away from them is that when you Cam them up the midrange turns to crap. The heads flow good enough to make 900rwhp which is great for a pure drag car but not for what we build 99% of the time.Then add on the intake selection.
I prefer a nice TFS,AFR type of head for a strong average power.
There's tons more info in that thread. I think that they could work for you, but there are a lot more results out there for the 243's.
Old 10-19-2009, 11:26 PM
i think im going to stick with the 243 heads.
Quick Reply: Compression vs CFM ??
