Ls1 inTake and TB
Old 10-21-2009, 04:00 PM
al3flangy's Avatar
Default Ls1 inTake and TB
i have LUMINA SS coupe ls1 engine w 6sd MT with DART heads , cam 118 , longtube headers w corsa catback and UD pulley so that i want best one of intake mainfold and TB ??
which one is better Fast 90,92,102 or nick william or bbk or .... ??
and how can i decied if i can fit 92 mm or 102 mm ??
can i fit ls2 or ls3 intake manifold on ls1 engine ??
Old 10-22-2009, 11:04 AM
bigboykilroy's Avatar
the 90mm isnt made anymore, u can get the used or some may still have new ones.
the 102mm is designed for the square port heads
LS6 are cheap like 350 now used.
LS2 you would need a MAP ext and you could use it.
I would personally go with a 92mm fast and a Fast 92mm TB ot NW TB
Old 10-22-2009, 01:52 PM
'00zbird's Avatar
I know I asked this in another thread, and nobody seemed to notice. Is it possible to take an ls6 manifold, and open up the mouth on it for a larger throttle body? Possibly 90mm or so? And would that big of a throttle body even bolt up to an ls6 manifold?
Old 10-22-2009, 03:04 PM
LS1-NAVY's Avatar
lingenfelter does a 90mm ls6 but they cut the snout off and glue another one on
Old 10-22-2009, 04:04 PM
al3flangy's Avatar
is there other ideas ??????
Old 10-23-2009, 06:26 AM
MonmouthCtyLS7's Avatar
Weiand , BBK, Professional Products typhoon are other options...LS2 and the LS3 wont do much more then your stock intake except for maybe a few hp in the higher rpms , plus there is extra parts needed for them to work...Id get the LS6 before either of those. All the intakes I listed above generally put out around the same hp as the LS6 on a stockish motor, if you can swing the Fast go for it w/ either a P&P stock TB or a matching mm one.
Old 10-23-2009, 06:37 PM
al3flangy's Avatar
what size of ls6 intake ?? what size of ls1 stock intake ?? ok if i want to install ls6 intake which one of throttle body can i install with it 90 mm or 92 mm ?? or do porting for my stock throttle ? what about maf should i porting it too or change it with other one ??
Old 10-23-2009, 06:55 PM
Johnnystock's Avatar
Theres a new 102mm FAST coming for cathedral port heads but it wont clear stock hood. I would go with a ported FAST 92mm combo. Proven and fits your hood. Its what I have and gave me 17rwhp and ok under the curve power like 4500-6400.
Old 10-23-2009, 07:06 PM
Only stock TB size fit on LS6 unless you cut the snout like said in another post but its not worth it. If youre going the LS6 route, go with a ported stock TB.
