D1SC F-Body Kit Question.........
Old 10-31-2009, 04:27 PM
underpressureWs6's Avatar
Default D1SC F-Body Kit Question.........
i was just wondering if the rubber tube going from the passenger side valve cover to the inlet hat on the blower has any significance if i already have a valve cover breather installed??? thanx in advance!
Old 10-31-2009, 10:03 PM
kkslds's Avatar
I have a breather in the oil filler tube, A kytp catch can with a breather on top of it and the line going to the hat from the front port.
I figured just incase it wasnt pulling in enough fresh air from the filler cap it would take care of it from the hat. The two back ports go to the kytp breather can to catch the oil and the harmeful gasses/condensation can escape through the breather on the can. Just got rid of the factory pcv system.
Yea you could probably get by without it, but whats the point? Why not just run the hose and call it good and not worry about it? Is there a reason your considering it?
Old 11-01-2009, 01:30 AM
aight sounds like it wont make any difference, i was just wondering cause i have the oil cap breather, if i really needed it, its been on the car for 3 years now so i was jus wondering lol does excess oil get into the blower then?? and will it harm it??
Old 11-01-2009, 01:26 AM
'Trust''s Avatar
Took that crap off a long time ago. I'd rather not have the impeller suck up oil.
Old 11-01-2009, 03:28 PM
i think im going to go ahead and get rid of the tube, should i just cap the valve cover where the tube went?? or do i need to run something there?? i dont remember what went there before i put the procharger on
Old 11-01-2009, 03:40 PM
'Trust''s Avatar
You can cap it.
Old 11-01-2009, 06:22 PM
conan's Avatar
I dont let the blower head unit suck vacume on my engine either. But you do need the crank case vented so watch just capping of the rocker cover. Are you still using the stock pcv system?
Old 11-01-2009, 07:15 PM
cool thanx, and yeah i still have the stock pcv system on the car....
Old 11-01-2009, 11:08 PM
conan's Avatar
Have a read through this thread. You might want to make some changes to the pcv depending on your boost level and how tight your ring gaps are.
https://ls1tech.com/forums/forced-in...rs-inside.html
Quick Reply: D1SC F-Body Kit Question.........
