Drag Racing Tech - Cam or stall?
Formula_LS1
11-04-2009, 01:49 PM
Can't decide what I should do. The thing is...my car already has a stall...a Circle-D 3000. The stall does do decently though, especially for what it is...consistently hits high 1.6 to low 1.7 60's. Would it be worth going with a bigger stall first or should I just go straight to the cam? If I did get a cam, it would be something decent sized, but I don't want anything too big or too small. Thanks for the help.
91RS383
11-04-2009, 02:34 PM
I'd cam it next. How much better do you want the 60' time with (per your sig) stock looking rear tires?
Formula_LS1
11-04-2009, 02:51 PM
Forgot to mention that I now run it on Convo Pro's...rear tires are 275/50/15 ET Streets, and I have skinnies up front. The car doesn't look quite so stock anymore haha.
BlackScreaminMachine
11-04-2009, 02:54 PM
Stalls are matched to cams and there are different requirements depending on what you pick. BUT a largish cam will not see true potention with out pairing it with the correct rear gear and converter.
PERSONALLY, I'd do a cam since you have something in there and its a quality 'verter BUT you should look at something 3500-4500 and you will really see a diff in performance.
Has the car been tuned? has the TQ management been decreased or removed?
Formula_LS1
11-04-2009, 02:57 PM
Yes...it's been fully dyno tuned for the bolt ons already.
Pro Stock John
11-04-2009, 04:22 PM
What are you looking to do with the car?
Personally I'd run at 4000 stall if I was looking for a strong balance of strip and street performance. A true 3000 stall is decent, but it's pretty small and it will seem ever smaller if you go to a big cam. How much cam you want to run 224/224 - 232/24x? Where in that range? Typically a 22x/22x cam is pretty mild, would work well with a smaller converter. A bigger 23x/24x would work better with a 4000-4500 stall.
Formula_LS1
11-04-2009, 04:47 PM
I'd probably be going with something in the 23X/23X range.
Pro Stock John
11-04-2009, 09:29 PM
I'd pick a cam and then see how your converter works out.
11-05-2009, 06:41 AM
Exactly!
91RS383
11-05-2009, 07:44 AM
X2 :cool:
JL ws-6
11-05-2009, 08:06 AM
Cam it, just put one in with a decent amount of advance in so it makes good power on the bottom end and it should work fine.
232/236 with a 111+4, or something like that and you should be good.
SPEED#1
11-05-2009, 02:30 PM
Cam it for sure
Formula_LS1
11-05-2009, 08:27 PM
I'd REALLY like to do the cam next...I'm just afraid my current stall might be too small.
MurderedOut
11-06-2009, 12:04 AM
Get the cam and since you ALREADY have the stall, if you wind up getting a cam thats a little big for a 3000 stall, just send it to circle d and have them restall it.
You can always have it restalled to whatever speed you need.
chrs1313
11-06-2009, 09:59 PM
did you end up buying that ss4000...i cant remember...if you did throw that bad boy in...i would not get in a rush with the cam it is the end of the season and you should research more and get a better idea of what you wanna do with the car...
no need to rush the cam install it is a good chunk of change...
Formula_LS1
11-06-2009, 10:19 PM
I did buy the SS4000. I'm not going to rush the cam install...most likely would not be doing it til spring...I just want to get a good idea what the cost will be and start buying parts if I have to.
chrs1313
11-06-2009, 10:36 PM
Larry will hook you up he is a good guy...no worries...
