is this normal (pic inside)
or should i say what is it suppose to be at. and if you let it seat a while longer the pressure goes to between 40 and 60 but when you drive it goes back just a little over 60
Kleeborp the Moderator™
To me, that looks normal. At idle just after started, my oil pressure gauge reads around 60 psi...after it is fully warm (oil temps 210+), the pressure at idle is usually around 40 psi or so, and cruising goes right back up to around 60 psi.
I'd only start shitting myself if it was reading really low.
I'm also going to move this to Gen III External Engine instead of the Fueling section.
Running GC 0W-30.
