Old 05-18-2016, 01:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
Parking Brake Adjustment?
Old 02-21-2010, 02:16 PM
ethan071891's Avatar
Default Parking Brake Adjustment?
Can someone please tell me how to adjust my parking brake, I have an 02 Z28 I looked over the drive shaft and didnt find anywhere to make adjustments maybe im just looking in the wrong place.
Old 02-21-2010, 03:19 PM
the_merv's Avatar
I know on the LT1 cars it's on the Calipers..maybe the same on the LS1 Cars..
Old 02-21-2010, 03:54 PM
thanks ill check that out
Old 02-21-2010, 07:34 PM
therealcreeper's Avatar
i thought 02's were auto-adjusting? who knows
remove the rear wheels and rotors, should be an adjuster behind that
Old 02-21-2010, 08:36 PM
DaddySS's Avatar
There is an adjuster on the anchor for the emergency brake shoes. Your have to remove the rotor and and turn it out a couple of clicks. You kind of have to judge how much to turn it out - you definitely do not want them too tight.
Old 02-21-2010, 08:38 PM
BobP's Avatar
They are self-adjusting on '01s and I can't imagine it's different for '02s. If it's way out of whack, you can adjust them at each wheel, then let it fine tune iteself. They're easier to get to with the rotors off - the mechanism is at the 6 o'clock position.
BobP
Old 02-21-2010, 10:29 PM
Thanks guys for all the help.
Old 02-22-2010, 10:36 AM
Save the manuals!
wssix99's Avatar
They are not self adjusting and never need adjustment unless you change rear rotors. (They need to be adjusted to match the bore of the drum inside the rotor.) The mechanism looks like a typical self-adjusting drum brake, but its not.
The adjuster wheels are inside the rotor's drum, so you'll need to take your calipers and rotors off to get to it - and you have to adjust each side independently. There's a bit of a procedure to it, which is included in this thread: https://ls1tech.com/forums/suspensio...ightening.html
Old 02-22-2010, 08:04 PM
Wesmanw02's Avatar
Good info.
As stated, its important to note that LT1 and LS1 parking brakes are completely different. LT1 parking brakes are integrated into the calipers, while LS1 cars use a parking brake in rotor hat, which means it has parking brake shoes inside the rear brake rotors.
I recently did a '05 GTO, which was extremely easy. Just pull back the parking brake handle boot next to the console and turn the asjuster nut. Unfortunately, F-bodies are not the same, and require adjustment of the actual shoes themselves.
Old 09-11-2019, 07:33 AM
snipescastle2's Avatar
Default Hey guys, this pretty simple to do. My right rear parking brake cable broke
My parking brake cable broke on me the other day. Simple replacement, one you get the cable installed into the backing plate and the pin end is attached to the fromt cable adjuster. Then you just loosen the arm on the back of the caliper and twist the nut to expand the piston. When you get the adjustment where the cable arm is tight enough to allow you to operate the arm but keep 3/16” space between the arm and the caliper body. As everyone has said previously, compressing those springs is hard keeping them that way,
using good zip ties( the ones with metal inserts) those are rhe best ones use there.
Quick Reply: Parking Brake Adjustment?
