Tb porting?
Old 02-23-2010, 08:43 PM
spdygon's Avatar
Default Tb porting?
if our stock Tb are 75mm , what would be the size after porting them ?
and can a BBK 80MM be ported, what size will end up as?
Old 02-23-2010, 08:46 PM
PowerShift408's Avatar
Stock is 78mm. When ported, the inlet size is not increased. If you feel in your throttle body, you will feel a distinct ridge. Removing that is the focal point of porting the throttle body.
Old 02-23-2010, 08:49 PM
spdygon's Avatar
my bad 78 it is.
i had some one tell me that porting the stock Tb would be better then a 80mm or 85mm BBK.
Old 02-23-2010, 09:46 PM
You'll get all the performance for a fraction of the cost. The stock intake inlet is 78 mm, so having a throttle body bigger than that will not do you any good.
Old 02-23-2010, 10:29 PM
02_Z28_G's Avatar
so by porting a throttle body your basically creating a smoother airflow correct?
Old 02-23-2010, 10:58 PM
Yes sir.
Old 02-24-2010, 02:05 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Moving to external.
Old 02-24-2010, 04:34 AM
Bo White's Avatar
Stock TB is 75mm but porting them makes it a true 75mm. Stock has a ridge infront of the blade that hinders flow.
Old 02-24-2010, 06:24 AM
MonmouthCtyLS7's Avatar
Originally Posted by spdygon
my bad 78 it is.
Inlet size is still bigger from the aftermarket TB hence more air flow. Not a huge differance but still more. Porting the stocker is definately cheaper. Ive had both but also swapped a intake so i couldnt tell u the differance if any.
