e.g.r or a.i.r
Old 03-18-2010, 11:27 AM
blackfbird98's Avatar
Default e.g.r or a.i.r
im sorry to be asking this and i know there is info on it but not anything that really helps. so im pretty new with the whole installing headers thing. but this week i am getting some pacesetter longtubes and they are the race addition (i own a 2000 z28) now i have read you need to remove the e.g.r? now what is that and how do i remove it? and does it need to be blocked off? and also for a.i.r does my car have that if my car has e.g.r? if so how do i remove that and does it also need to be blocked off? just want to make sure i go about the install correctly and have everything hooked up and ready to go. any input is appreciated.
Old 03-18-2010, 11:36 AM
Mart00SS's Avatar
Using the Search Function effectively on this site will really help you.
See the pipe that is coming up out of the intake behind the throttle body. That pipe and the large valve that it leads to is the EGR. It Conncects to the exhaust mainifold on the passengers side. The hole in the top of the intake will need to be plugged once its removed. AIR is the two hoses coming staight up off each exhuast manifold. Its pretty self explanitory. Lookat your headers, look at your stock manifolds and you will see the difference in what does not connect to the headers. Use the search function and be sure to search titles only for EGR and AIR.
Old 03-18-2010, 12:01 PM
Mart00SS's Avatar
Look what I accidentally came across.
https://ls1tech.com/forums/new-ls1-o...uestion-2.html
Scroll down a bit and there is a good diagram
Old 03-18-2010, 12:08 PM
brian_rs/ss's Avatar
or you could have just read that thread where some1 asked the same question as you...that was posted yesterday and is still on the front page.
venom 13's Avatar
Here is thread where others chimed in to help me with the removal: https://ls1tech.com/forums/generatio...questions.html
Hope this helps.
Old 03-18-2010, 12:10 PM
slt200mph's Avatar
Just remove all the AIR and EGR stuff and chuck in the trash..it is just dead weight.
yeah that one ^
Old 03-18-2010, 03:04 PM
including the airpump?
Old 03-18-2010, 03:10 PM
yes including the air pump. and all the hoses/connections.
Old 03-18-2010, 04:54 PM
slt200mph's Avatar
Hell yeah it is the part the weighs the most ..
Old 03-18-2010, 05:26 PM
now how many of those block offs do i need and which ones? i was getting confused when reading that other thread i just want to make sure i get the right ones and right quantities. i appreciate the help btw.
Old 03-18-2010, 06:43 PM
Mart00SS's Avatar
you said you have race style headers, they dont need block off plates because there are no spots for air or egr connections. the only thing you will need to do is plug the hole in the intake where the egr pipe went.
Old 03-18-2010, 07:03 PM
venom 13's Avatar
That piece can be ordered from Thunder also. Check in that thread I linked you to and follow the link in there. That part is located toward the end of the list.
Old 03-19-2010, 11:25 AM
thats it? so nothing needs to be blocked off when i take off the air pump? and will my car run weird with all that off?
Old 03-20-2010, 11:52 AM
puggerton03's Avatar
you have to have the air and egr tuned out of your computer. id reccomend getting a tune anyway after you put headers on. i sent my computer to frost for a mail-order tune and had it back in a couple of days and was only about 140 bucks after shipping. just take off all the air stuff and tie the wires up.
Old 03-20-2010, 05:55 PM
mikestypes's Avatar
On an 01 car, can #5 be removed when removing the air system?
I just removed the system, but I left #5 on and plugged the lower port on it that used to supply #4.
What is #5?
Old 03-23-2010, 09:43 PM
mikestypes's Avatar
Looking for a clear solution. Thanks.
Old 03-23-2010, 09:46 PM
fucter's Avatar
no, post the stuff on craigslist
