Help hotchkis lowering spring
Me and a friend of mine have a 2000 and 2001 SS and we ordered Hotchkis sport suspension lowering springs and kyb GY-2 shocks. My question is the springs was the same height as the stock spring that came off the car is this normal? I thought they would be shorter to give it the drop. We installed them and the shocks and the car sits same as stock, i know they will settle a little after some miles on them but i dont see them coming down an inch and a half like the hotchkis box said. Whats wrong or will they come on down with time.
I would like to get about the car down about an inch and a half all the way around i can do the heater hose thing in the back but what can i do to get the front down a little more.
A lot of times the factory springs are wore and the height of the car is already dropped from this. This can be some of the reason why when lowering springs are installed you see the same height results.
If you have any pictures of the cars to post we can look at the height and let you know.
Moderator
My Hotchkiss dropped the car exactly 1" at all 4 corners.
I measured all 4 corners before / after.
Now, this is my second set of "Hotchkiss", the first I
bought used and got scammed, receiving some stock
appearing springs.
They are progressive, starting with a near-stock rate
so seeing a near-stock uninstalled height is not too
unreasonable.
appearing springs.
unreasonable.
