removing weight- what is this part?
I was removing some things today under the car to shed some weight and I came across this plastic box with a vacuum line goin to it on the passenger side of the car next to the horns. what is this part? can I just plug the vacuum line and remove it?
you can see this part from the access panel under the front bumper on the passenger side.
this part is located directly behind the horns.
