Stuck in fourth!!!
Old 04-14-2010, 01:02 AM
lilmiller74's Avatar
Default Stuck in fourth!!!
I have an 02 z28 and I was at the track and shifted into fourth and now it is stuck,the clutch still works. any ideas and suggestions on how to fix this would be appreciated.
Old 04-14-2010, 07:01 AM
85MikeTPI's Avatar
9 times out of 10, a stuck gear is from a broken synchro key. On 3-4 it can also be a bent/broken shift fork.
Not much to do other than pull the trans and tear into it..
Old 04-14-2010, 07:19 AM
VincesSS's Avatar
Kick that biatch out!
Old 04-14-2010, 01:51 PM
Bad Notch's Avatar
Do 10 WOT clutch drops and see if that helps.
But seriously, its a key problem. The trans will have to come out. While your at it D&D sells the upgraded 3-4 steel clutch fork for $44 dollars
Old 04-14-2010, 09:10 PM
That is what all my buddys have said it probably is, and thanks for the info fellas.
Old 04-14-2010, 09:29 PM
thesource's Avatar
Yep, you more than likely bent the shift keys. Kick it out of gear and finish off the keys. They will break completely and fall to the bottom of the transmission.
Old 04-14-2010, 09:54 PM
Haha sounds like a bad idea, the thing that sucks is i just had the tranny out about a month ago putting a clutch in, not looking forward to having to pull it again.
Old 04-16-2010, 05:27 PM
02SOMWS6's Avatar
I would guess a broken slider key. It will pop out and drive like theres nothing wrong-- dont be fooled by that. The trans needs to be torn down before it causes a chain reaction of broken parts
Old 04-17-2010, 10:18 PM
bearcatt's Avatar
+1
yep, you more than likely bent the shift keys. Kick it out of gear and finish off the keys. They will break completely and fall to the bottom of the transmission.
+1
Old 04-18-2010, 01:34 AM
nmass399's Avatar
Yeah mine got stuck in fourth making a pull on the interstate last year, drove my buddy the rest of the way to his place then got back on the interstate and then on to another highway(about 10 miles or so) and it popped right out of gear.
Just thought i would tell ya.
Old 04-18-2010, 04:15 PM
billymz28's Avatar
mine did the same thing but I couldnt kick it out of gear for nothing apparently the rod that the shifter bolts to snaped. Most likely a shift fork though
Old 04-19-2010, 07:42 AM
PewterScreaminMach's Avatar
x2. Had the same thing happen to me a couple weeks after I got my car. Broken key was wedged, preventing it from coming out of gear. Time for a rebuild.
Old 04-19-2010, 09:23 AM
tx3
tx3's Avatar
x3 samething happened to me.. pulling in to a parking lot going to downshift to go up a hill and got stuck in fourth.. had to get in the backseat and kick that ****** out. did it again on accident and took it for a drive and got the R's up and it shifted right out.. just dont do it that way or else youll need a new clutch too! i was putting a new one in at the time anyways!
Old 04-20-2010, 04:18 AM
thewholefnshow1's Avatar
Hell at least yall went in a gear cause mine wouldn't go into none without a hitting and forcing the shifter into it but it's at my tuners shop. I'll be doing the viper upgrade long story short.
Quick Reply: Stuck in fourth!!!
