ls6 intake
Restricted User
ls6 intake
Ok so I read up a little bit on the ls6 intake and have some questions.. I shouldn't have to alter anything, but the egr right? As long as I cut the bottom things off the ls6 intake I do not need the coolant pipes or rear coolant plugs right?
if u have stock manifolds you will need egr block off plates, and yes taking out the ribs underneath will let it fit right over the stock coolant crossover.
