H/C N/A LS1, going crazy, tr55 or tr6 plugs!!
Old 04-24-2010, 03:44 AM
SimRacer1's Avatar
Default H/C N/A LS1, going crazy, tr55 or tr6 plugs!!
So I have tr6s in right now, they were in because of some nos work but thats all gone now and back to N/A. Ive done TONS of reading on here and other LSx forums about this. SOme guys say for every 100 hp above stock and high compression go a step colder. Others say their 55s work unreal with their H/C cars.
So its about 50/50 on whats best for high compression N/A H/C LS1s. From tons of reading, it seems the tr6's should be gapped to 0.040 - 0.045 since its N/A and not running any juice. I think they come stock either 0.035 or 0.039.
I know the tr6s are safer as they run colder, but if overly cold they will foul. What do you guys think??? Some say the tr55s are getting close to their limit on hi compress H/C cars, others say they run beautifully.
Just for more info, im getting new plugs because I had a bad o2, so changing the plugs just in case the bad o2 fouled the plugs. I prob ran 1000-2000 miles with the bad o2, although there wasnt much WOT.
Old 04-24-2010, 03:27 PM
SimRacer1's Avatar
should i just stop worrying and order some tr6s and get them gapped appropriately??
Old 04-25-2010, 05:43 AM
Nitroused383's Avatar
Honestly I've ran both Tr-55's and Tr-6's on my N/A motor. I have 8.8:1 dynamic compression so I changed over to the Tr-6's. Made absolutely no difference, but I do know the engine runs a little safer now. If someone tells you the Tr-6 is a nitrous plug you need not listen to them There are guys running 7-8-9 series plugs in their low compression turbo cars, I don't think they are fouling plugs out cruising around.
Old 04-25-2010, 05:57 PM
SimRacer1's Avatar
cool thanks for the input, much appreciated
Old 04-25-2010, 06:34 PM
transam150's Avatar
our local advance and orilleys carries ngk tr6 and yes they are a much colder plug than stock. I shoot 350 worth of nitrous on them all the time and change them once a month. gaped to .35
Old 04-25-2010, 09:46 PM
chrs1313's Avatar
11.9 to 1 compression 346 here...gapped at .035 tr6...put down 485rwhp through locked a4 12 bolt
seems to work for me...also Patrick g's 500rwhp build uses the same tr6
Old 04-26-2010, 04:57 AM
SimRacer1's Avatar
sick thanks, do u change wires everytime u change plugs???
Old 04-28-2010, 08:35 PM
thislswon's Avatar
TR6's here also. Yes im a nitrous car but would be running TR6's regardless
Quick Reply: H/C N/A LS1, going crazy, tr55 or tr6 plugs!!
