Not shifting @ high rpm?? M/C problem??
Spec stage 3, has about 2500 miles on it..RPM stage 5 t-56.. Stock master cylinder with very low miles and fluid is clear..Is the m/c the problem and if it is which one is the best???
Pushing that kind of power I'd say your hydraulic system needs to be upgraded. The Tick Performance adj. mc should correct that problem. As far as the drill mod I think I've read more that it didn't help than it did. Especially when you get to the power level your at.
Get yourself a Tick master cylinder. I make the same hp on motor as you and use the same clutch. I tried a brand new GM master with the drill mod and made it adjustable, but the clutch still would drag above 6600rpm. Put the Tick master in and now I powershift the wee out of it at 7000rpm. It's expensive, but worth it!
Tick m/c = fixed problems. I've explained it in a couple of threads but your are putting out too much power and the stock m/c doesn't push enough fluid to fully disengage the clutch.
