Problems at dyno today
Ok so I resently had a 5.3 stage 2.5 heads from tsp along w tsunami cam, lt pace and ory installed and rod bolts to strengthen the bottom. Went to RPM in garner to have it tuned, first pull nothing done, 418 hp 385 tq. second pull w some changes, lower and so on untill a terrible clanging sound durring a pull. Turned off and started again. Not making sound at idle but after 1500 there it goes. pulled valve covers off and inspected heads, good. Took switches off of injectors one by one while car was making noise and found out it was the first cylinder. Likely a bearing they say, idk. Looking for some help. Any info would help thanks guys.
so a couple of guys say it was the mechanics fault when he installed the rod bolts. Say he should have put new bearings in and could have forgotten to tighten one. May have been missmatched rod caps, who knows untill it gets broken down. gonna see if he will take a look at it.
A guy in the army. Names brandon. Hes done several head and cam swaps on ls1s ls2s. You can look up his work on youtube under tsunami cam camaro. his user name is socumguy or something. My vids are there to.
FYI, you should never just flop new bearings in while doing the rod bolts. New bearings require the big end to be put back in round. Also what rod bolts were installed? ARP's or Katech's? If you used ARP's the big end needs to be put back into round as well. Katech's are the only purely drop in rod bolt.
soon hopefully. will keep everyone posted. i dont have the tools and equipment so ill have to pay someone to do all the work. the guy that did the work is in the military and just got into med school. got shipped to texas for that so he cant do anything for me. This was all unexpected so hope to get workn on it though.
