Pontiac GTO 2004-2006 The Modern Goat
06 gto fuel rrails and injectors.....will they fitt on my 04 gto?
Old 05-28-2010, 02:30 AM
GTOdave's Avatar
Default 06 gto fuel rrails and injectors.....will they fitt on my 04 gto?
ok my buddy has the 2006 injectors and fuel rails and i have an 04 gto and was wondering if they will fitt?
thanks guys
Old 05-28-2010, 08:24 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
06 is an LS2 with different injector connectors & injector heights, so it is not a direct fit.
Old 05-29-2010, 02:50 PM
Buzzmanb12's Avatar
They will fit perfectly, you will need some injector adapters for them to work though.
Old 05-29-2010, 03:59 PM
george g's Avatar
cheaper to just buy a set that will fit.
Old 05-29-2010, 08:20 PM
Ethan[ws6]'s Avatar
Not when they were only 50 bucks lol
Old 05-31-2010, 12:12 AM
BillyBob750's Avatar
Couple of things to keep in mind..
- LS2 injectors are much shorter than the LS1 injectors
- LS2 and LS1 injectors have different wiring plugs, so you'll need harness adaptors
- LS2 fuel rails will not bolt directly onto an LS2 intake.. LS1 fuel rail bolts are offset from the intake bolt holes, while the LS2 stuff is directly in-line.
Old 05-31-2010, 11:14 PM
Ethan[ws6]'s Avatar
Wiring harness adapter? that's retarded lol. I was hoping these things would just slide in and be good to go
Old 06-01-2010, 02:54 AM
402GOAT's Avatar
I have a set of adapters from fast that will work for you. They are brand new. Pm me if you are interested. I payed 30 but shoot me a price.
Old 06-02-2010, 03:22 PM
GTOdave's Avatar
man i want them.. ethan.. i'll give you 400 dollars for them RIGHT NOW
