Any Prospeed Porsche brake kits left?
Old 01-13-2004, 10:23 AM
Scalpel's Avatar
Default Any Prospeed Porsche brake kits left?
This seems like the most cost effective route in the grand scheme of things for:
  • Reliability
  • Performance
  • Access to parts and service
Anyone have a used kit or know of a new kit that's for sale?
Old 01-13-2004, 02:47 PM
Darkhalf's Avatar
  • Reliability
  • Performance
I don't think there is any left, unless you find someone that has yet to install one and wants to sell it. However instead of PSM there is Stoptech and Movit which are pretty much identical to Prospeeds.
Old 01-13-2004, 09:21 PM
roy
roy's Avatar
even thoughProspeed uses the same caliper Movit , it is leagues below in fit and finish and engineering of the components as compared to Movit or Stop tech.
just my thoughts after seeing one.
Old 01-14-2004, 06:36 AM
mitchntx's Avatar
Curious .... Does the Movit kit require shimming the bracket for alignment?
Old 01-15-2004, 02:19 AM
roy
roy's Avatar
Mitch
I can say my brackets in the front needed no Shims. My park brake caliper needed a a couple of small shims to center the caliper on the bracket though.
Old 01-15-2004, 06:24 AM
mitchntx's Avatar
Was that by luck, design or a trip to a machine shop??
Old 01-15-2004, 09:38 PM
roy
roy's Avatar
I would like to think By design,since Movit installed the kit.
Old 01-16-2004, 05:13 PM
Racehead's Avatar
The Prospeed brackets are CNC machined and very accurate. The shims are provided because of design tolerances in the oem spindle, not bracketry. If you were able to bolt on a fixed caliper/fixed rotor setup to the traditional GM quality control manufactured spindles with no alignment issues, then god himself was smiling on you that day.
Old 01-17-2004, 04:04 AM
roy
roy's Avatar
Hey race you have a pic of prospeeds mount bracket? I am sure they incorporated some changes in later kits.
Old 01-17-2004, 05:03 PM
Pimp C's Avatar
Where can we get movit kits in the u.s? The ultimate garage is no longer a reseller.
Old 01-17-2004, 07:16 PM
Racehead's Avatar
Sorry I have no pre-install pics of these brackets, however NataSS inc has an uninstalled kit from the last batch of 12 that were sold ( as were mine ) I'm sure he could send you some pics if you wanted to see them.
Old 01-17-2004, 09:18 PM
roy
roy's Avatar
Thanks Race,
Hey Nata you wouldn't happen to have a pic of the mounting bracket that you could post ? would ya
Quick Reply: Any Prospeed Porsche brake kits left?
