ARP head stud torq specs???
So i got some used arp head studs and im curious to what the torque spec is on them maybe even if there is a special order in which i should tighten them?
Thanks,
Nick
Thanks,
Nick
are you sure about that. my buddy torques his studs then the nuts holding the heads on. i cant remeber the spec. but i beleive if they are hand tight they can come loose. Again this is just my opinion.
Village Troll
I could give two ***** of the when/where/why/how of your friend or the reasoning. The fact of the matter is head studs only need to be hand tightened into the block. If you don't understand why then educate yourself instead of arguing your opinion.
Didnt say that actually it was more of a question. personally i dont like studs so ive never used them. and im not claiming to know anything about them, but this is good information to know. and hahaa at you ss rrr your funny.
the correct way is to put the stud in by hand.....when it stops turning you stop turning.....do not tighten them as much as you can by hand just stop when they stop.........use sealant on the end in the block and moly lube on the nut on the top.....also do not go straight to the 70ft/lbs......run three tightening sequences in the correct bolt pattern order 35lbs...55lbs....70lbs.....this will lay out the gasket nicely and give you a better chance at a good seal...........also THIS IS VERY IMPORTANT!!! !! if the studs are NEW install the heads and torque....start the motor and allow it to come up to temp then shut it off and let it completely cool then retorque the studs.....this only has to be done with brand new studs but make sure you do this....espically if you are running a metal layer gasket such as a cometic
hope this helps!!
