advanced induction?
advanced induction?
thinking about buying one of their set ups but want to know if it will be worth it, i have gasket matched heads and a 233-239 cam and it went 12.3@114 on a 2.0 60 foot. wanting to know how much the A/I set will help or if its not even worth it. let me know what you guys think
I am sure with heads done completely(full port job)the cam you already have will be alot better.Do you have 1.6rr on that cam now? Thats an old Comb. Motorsports grind and it makes good power. A friend here had that in a 97Z28 and ran 12.4 untouched heads +valvesprings all bolt-ons.
The AI spec set ups along with LE will give you a substancial gain above your current combo,provided you have all complimenting mods and of course a great tune!!!!!!!!!!
Judging from your 60' you have traction issues or the lack of a good stall converter..before you add more power and spending more money get the current power to the ground..... MPH is good, what altitude and DA are you running in?
yea, im not to good at launching my car with the clutch its got, its either stopped or going, hard to slip it. and no traction problems just need to raise launch rpm. and yea i love that cam, and yea i have the RRs and all bolt ons so hopefully with new heads it will gain some decent power.
They know what they are doing but if your looking to go faster just start buying parts that will help get you down the track, and I'm not talking about more power. good clutch and some traction parts like shocks springs control arms and relo brackets plus a good set of tires for the track.
Tireburnin--just looked at your sig. That is a CRAZY mph for running a 7.24 in the 1/8th! Obviously your car had 6's in it, lol. What was wrong with the setup? Not enough tire? Too soft of a converter?
I think it was really a combination of issues. The car was setup for nitrous so the converter didn't stall very high on motor. The converter flashed to 3500rpm on the brake.
Another issue and probably the biggest was the track. Most of my times were run at Qualcomm Stadium at the Racelegal track in the parking lot. Basically a parking lot track where only the first few feet are really prepped.
The car could have used a diet too. It was right around 3,5XX lbs with driver. Since then I have done tubular suspension, fiberglass hood etc.
All of these things combined to make it very dificult to hook up. The car went a best of 1.59 at that track and usually averaged 1.65-1.68. With those kinds of 60ft times it made 6s impossible. I know that the car had it in it because every time it would hook, the MPH would climb even more. At our real track (very good prep) in the mountains (3-4,000 da average) I hooked and would run 7.2X at 95.5mph with a 1.58-1.60 60ft.
But that setup is all water under the bridge. The car is losing lots of weight, gaining TONS of power from a big cube LS3, getting a carb, getting suspension work and hopefully some new times this year!
I think it was really a combination of issues. The car was setup for nitrous so the converter didn't stall very high on motor. The converter flashed to 3500rpm on the break.
