high temps with thae AC on
I recently installed a cooler on my 98 ws6, the car runs cool temps with out the air conditioner on. But when I turn on the air it start to run a high temp of 205 almost touching 210. I turn it back off it goes down, can any body help me with this problem,
Moderator
First thing, pull the top support and blow out the condenser
and rad fins with shop air. Expect a bountiful harvest of crap.
But the stock rad is a wmipy little bitch and an LT1 radiator
woud help you out a fair bit, if you are ready to swap (like
at coolant /WP change).
Are you running the tranny cooler inline with the radiator? If so then remove the lines and just run the tranny fluid through the cooler and thats it. It will make a huge difference on temps. That is the way mine is set up. I was driving in town today and the water temp never got over 185 and the tranny temp never got over 160. And that was with the AC on wide open.
No I'm not running it through the radiator, I bypassed it. And while I was sitting in traffic it started to run hot and when I got to moving again my tranny was acting like it was slipping I turned off the a/c and it cooled back down, and when I parked the car for awhile , and got back in it to go home it drove good with no problem
For a stand alone transmission cooler from what I have been told that one is to small. You should have one with no less than 30000GVW. Part number 20274 would be better.
Based on what I have been told I just ordered Tru-Cool 4921-1 with a 30000GVW and a BTU rating of 34000.
Regarding your overheating problem you probably don't have enough air flow through the radiator. Maybe clean the radiator fins? Maybe more airflow with a bigger fan(s)?
Ok I'll try that and see if that help. I also have the cooler side ways, so I should redo that to so it can be in a up right position also. Dam sure did'nt want to go throught that again but it's all for the love of the bird right don'nt want to mess up my up graded tranny an my yank ss3600...
You want to air to flow through the trans cooler and of course across the fins. If the trans cooler was up next to the radiator or A/C condenser it will have the fans helping it cool when stopped and then the movement of the car will add air across it.
"so do you recommend I also get a bigger cooler also?"
I don't know your situation. I'm just going by my research and talking to manufacturers. For a stand alone 30,000gvw is a minimum. I'm sure that is to most situations. I would do some independent research and maybe talk to the people who made your torque converter for advice.
Im no chemist, I dont know the properties of trans fluid. Stock trans' run pretty hot so I assume trans fluid is designed to work well when hot. With my external cooler only, on a 60 degree day, I cant hardly get my trans up to 115 degrees. I know thats prolly not the best, but it just feels so damn good
