So a T56 takes 4 quarts?
Old 07-07-2010, 12:15 PM
Jays_SSZ28's Avatar
Default So a T56 takes 4 quarts?
I have a T56 out of a 2000 camaro.
It's been in the garage draining for 2 weeks because I ordered the recommended 88861800 Manual Transmission Fluid from GM. (didn't know it would take this long to get it)
I'm just going to pump 4 quarts in it. Not going to go with the 'til it comes out of the fill hole' method.
Is this acceptable?
I'm asking because the mustang guys with T56's have something they call the 3.2 fill. And some use Mercon V. I'm guessing this is 3.2 quarts and it helps shifting somehow. I don't know.
Old 07-07-2010, 12:23 PM
brians91formula's Avatar
I think it takes a little under 4 quarts. The "fill until it comes out" method is honestly your best bet. You DO NOT want to overfill.
Old 07-07-2010, 01:15 PM
killagt's Avatar
yea just buy 4 quart, I let mine drain out all night, next morning I fill it up and it take almost 4 quart. so just buy 4 quart and you good to go, dex III cheap type work great. I use oreilly brand. advance auto part brand work well too.
Old 07-07-2010, 01:16 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Yup fill until it starts to come out, make sure the car is level though.
Old 07-07-2010, 02:01 PM
Jays_SSZ28's Avatar
I'm actually taking out the parts store fluid and going with the newer (4 years ago) GM recommended fluid (which is not Dex III or Synchromesh).
It was only $3.03 per quart, can't go wrong, hopefully.
Old 07-07-2010, 09:37 PM
winger4800's Avatar
where did you get it from??? if from the dealer do you the name of it or a part number???
Old 07-07-2010, 10:23 PM
Jays_SSZ28's Avatar
Part number 88861800, I put that in google and clicked shopping.
I read about it here. https://ls1tech.com/forums/manual-tr...iii-atf-2.html
And found the quote below here: http://www.sandyblogs.com/techlink/2...dexron-vi.html
TIP: Any vehicle that previously used DEXRON-III for a manual transmission or transfer case should now use p/n 88861800 (88861801 in Canada) Manual Transmission and Transfer Case Fluid.
Old 07-07-2010, 11:22 PM
HavATampa's Avatar
I agree with the other guys, dont just fill it with 4 qts. and call it good. It's impossible to get all the fluid out and if you overfill it, it's just going to come out the vent tube on top of the tranny and make a mess under your car while you are driving. Let us know how the tranny feels with the new fluid. This Dexron VI debate has been going on for a few years and everytime I find a thread that seems to be clear cut on why we should or shoudn't use this stuff in our T56 transmssions, I find more threads that make me change my mind. I've been using regular Dex III for years and have a 2000 model like you that supposedly has the paper lined blocker rings, which may or may not be damaged by using synthetic fluids, that's another debate by itself. I've seen threads that says Dex VI is synthetic. Is that true?
Old 07-07-2010, 11:27 PM
quews6lime's Avatar
yeah buddy
Old 07-07-2010, 11:33 PM
killagt's Avatar
I dont see no 3 dollar a quart ?
Old 07-08-2010, 12:54 AM
Jays_SSZ28's Avatar
It was $5.37, no idea where I got $3 from.
Old 07-08-2010, 01:06 AM
Jays_SSZ28's Avatar
Originally Posted by HavATampa
I agree with the other guys, dont just fill it with 4 qts. and call it good. It's impossible to get all the fluid out and if you overfill it, it's just going to come out the overflow tube on top of the tranny and make a mess under your car while you are driving. Let us know how the tranny feels with the new fluid. This Dexron VI debate has been going on for a few years and everytime I find a thread that seems to be clear cut on why we should or shoudn't use this stuff in our T56 transmssions, I find more threads that make me change my mind. I've been using regular Dex III for years and have a 2000 model like you that supposedly has the paper lined blocker rings, which may or may not be damaged by using synthetic fluids, that's another debate by itself. I've seen threads that says Dex VI is synthetic. Is that true?
I put 4 quarts in with the car on it's side, set it down level and it just trickled out the fill hole.
I emptied the drain pan into the empty containers and almost exactly 4 quarts came out.
I took out Castrol Dex/Merc.
This fluid I put in smells bad, sounds like water in the bottle, shifts are a little notchy? it goes right in gear no problem but the feel is different. It works ok.
The Dex VI is full synthetic, been thinking of putting that in my truck (4L80E). Even the super tech dex vi says synthetic on the bottle.
Old 07-08-2010, 01:16 AM
Arc00TA's Avatar
I've always just dumped 4 in the shifter area and went on my merry way. Never had a single issue except when I tried syncromesh which was great for about 200 miles then it grind like **** every time. Put dex III back in and it was good to go again.
Old 07-08-2010, 07:19 AM
killagt's Avatar
Why are you using dex vi ? yes gm change the spec , but I read and seem it give problem to these tranny, stick with dex 3 or synchromesh. but since it already on the tranny, tell us how it go.
Old 07-08-2010, 10:02 AM
Jays_SSZ28's Avatar
Where do you see that I'm using dex vi? I am not.
Old 07-08-2010, 10:16 AM
lowaggie's Avatar
not to hijack, but I've been using the dex vi stuff for about 15K miles now, and it works great. I drained a little bit out to check the fluid, and it looks likes new. My shifts are really nice, or as nice as a T56 can be! I would recommend it, it feels better than the syncromesh that I ran for 50K miles.(changes every 15K miles)
Old 07-08-2010, 10:17 AM
killagt's Avatar
I dint read your whole sentence, it say for your truck.
Old 07-08-2010, 02:01 PM
BriancWS6's Avatar
I've been running Pennzoil Synchromesh for years with no issues. If you let the tranny drain completely, 4 quarts will be just right, it always has been for me.
Quick Reply: So a T56 takes 4 quarts?
