changed oil now change oil light comes on
so i changed my oil a couple days ago now only in high rpms does the change oil light come on. kind of wierd. any ideas. i used mobile 1 5w 30, 6 1/2 qrts. and filter.
Like I said I thought it was a lot also but if you look at stickys on this site that's what it says. I know I sound like a dumb *** but just following the info. I should have stuck with my gut.
you not confuse with tranmission fluid and oil right ? 6+ quart look like for automatic tranmission, you not miss read that and think that how much for engine oil right ? if ok if you do, just kinda loose the drain plug and get some out.
General Data
Engine Type V8
Displacement 5.7L-5665 cc 346 CID
Bore 99.0 mm 3.898 in
Stroke 92.0 mm 3.622 in
Compression Ratio 10.1:1
Firing Order 1-8-7-2-6-5-4-3
Spark Plug Type 41-931
Spark Plug Gap 1.524 mm 0.06 in
Lubrication System 5.678 Liters 6.0 Quarts
Oil Capacity (without Oil Filter Change) 6.0 Quarts 5.7 Liters
Oil Capacity (with Oil Filter Change) 6.5 Quarts 6.151 Liters
Oil Pressure (Minimum -- Hot) 41.4 kPa at 1,000 engine RPM 6.0 psig at 1,000 engine RPM
Oil Pressure (Minimum- Hot) engine RPM 124.11 kPa at 2,000 engine RPM 165.48 kPa at 4,000 engine RPM
Engine Type V8
and blinker fluid would be nice hehe
IM SURE IT FOR TRANMISSION ATF ! I seen 5 quart only, 5.5 quart if you use BIG long filter.
I've also heard if you remove the box thingy where the filter is and plug the big hole in your tb you will also have hp gains also using an exhaust stretcher............lol come on now how retarded do you think I am. And the page I copied was a sticky for internal engine specs nothing to do with the tranny.
yes you are PeterTard
2002 firebird specifications
12.9 / 365
rear of first seat with second seat down: 33.7 / 954
Fuel tank capacity (gals / liters):
16.5 / 63
Engine oil / filter (qts / liters):
5.7L V8: 5.5 / 5.2; 3.8L V6: 4.5 / 4.3
Engine coolant (qts / liters):
Manual:
3.8L V6: 11.6 / 11.0
5.7L V8: 11.9 / 11.3
Auto:
3.8L V6: 11.4 / 10.8
5.7L V8: 11.8 / 11.2
12.9 / 365
16.5 / 63
Manual:
Auto:
lol u havent drain it yet ? what oil filter did you use ? are you using big version filter ? it hold about half or more quart, and help trap more dirt then small filter.
