changed oil now change oil light comes on
Old 07-10-2010, 09:48 PM
drago1217's Avatar
Default changed oil now change oil light comes on
so i changed my oil a couple days ago now only in high rpms does the change oil light come on. kind of wierd. any ideas. i used mobile 1 5w 30, 6 1/2 qrts. and filter.
Old 07-10-2010, 09:59 PM
93batmobile's Avatar
i never put more than six in, dunno if too much oil will cause a light to come on or not, never had that issue lol
Old 07-10-2010, 10:10 PM
rtr2001ss's Avatar
Did you reset the monitoring system? And this is the change oil light, or is it low oil light? 6.5qts does seem a bit much though, usually 5.5 to 5.75.
Old 07-11-2010, 01:38 AM
drago1217's Avatar
I thought it was a bit much myself but I got that off this site, lol. I will reset it and I was going to drain some of it out also
Old 07-12-2010, 07:53 PM
blades11b's Avatar
if you use your dipstick.. it will tell you if you have too much oil..
Old 07-12-2010, 08:14 PM
drago1217's Avatar
Really I thought that was where you put exhaust grease, man I'm gonna have some problems tomorrow
Old 07-12-2010, 08:18 PM
3.8redbird's Avatar
Next your gonna tell us you put 8 gallons of blinker fluid to lube your muffler bearings
Old 07-12-2010, 08:23 PM
killagt's Avatar
man wtHELL ?
Old 07-12-2010, 09:15 PM
LS-1Z28's Avatar
wow 6 1/2 quarts... I normally only use 5 quarts when I do an oil/oil filter change. Try taking some of the oil out and see if that helps out.
Old 07-12-2010, 09:18 PM
LS-1Z28's Avatar
Old 07-12-2010, 09:43 PM
drago1217's Avatar
Like I said I thought it was a lot also but if you look at stickys on this site that's what it says. I know I sound like a dumb *** but just following the info. I should have stuck with my gut.
Old 07-12-2010, 09:54 PM
killagt's Avatar
you not confuse with tranmission fluid and oil right ? 6+ quart look like for automatic tranmission, you not miss read that and think that how much for engine oil right ? if ok if you do, just kinda loose the drain plug and get some out.
Old 07-13-2010, 10:54 AM
drago1217's Avatar
General Data
Engine Type V8
Displacement 5.7L-5665 cc 346 CID
Bore 99.0 mm 3.898 in
Stroke 92.0 mm 3.622 in
Compression Ratio 10.1:1
Firing Order 1-8-7-2-6-5-4-3
Spark Plug Type 41-931
Spark Plug Gap 1.524 mm 0.06 in
Lubrication System 5.678 Liters 6.0 Quarts
Oil Capacity (without Oil Filter Change) 6.0 Quarts 5.7 Liters
Oil Capacity (with Oil Filter Change) 6.5 Quarts 6.151 Liters
Oil Pressure (Minimum -- Hot) 41.4 kPa at 1,000 engine RPM 6.0 psig at 1,000 engine RPM
Oil Pressure (Minimum- Hot) engine RPM 124.11 kPa at 2,000 engine RPM 165.48 kPa at 4,000 engine RPM
Old 07-13-2010, 10:56 AM
drago1217's Avatar
ive reset the change oil light though and it doesnt come on anymore
Old 07-13-2010, 12:36 PM
fresh99z28's Avatar
dont forget to grease you radio volume buttons after the oil change, helps with hp
Old 07-13-2010, 12:41 PM
killagt's Avatar
and blinker fluid would be nice hehe
IM SURE IT FOR TRANMISSION ATF ! I seen 5 quart only, 5.5 quart if you use BIG long filter.
Old 07-13-2010, 01:03 PM
drago1217's Avatar
Exclamation
I've also heard if you remove the box thingy where the filter is and plug the big hole in your tb you will also have hp gains also using an exhaust stretcher............lol come on now how retarded do you think I am. And the page I copied was a sticky for internal engine specs nothing to do with the tranny.
Old 07-13-2010, 01:09 PM
killagt's Avatar
yes you are PeterTard
2002 firebird specifications
12.9 / 365
rear of first seat with second seat down: 33.7 / 954
Fuel tank capacity (gals / liters):
16.5 / 63
Engine oil / filter (qts / liters):
5.7L V8: 5.5 / 5.2; 3.8L V6: 4.5 / 4.3
Engine coolant (qts / liters):
Manual:
3.8L V6: 11.6 / 11.0
5.7L V8: 11.9 / 11.3
Auto:
3.8L V6: 11.4 / 10.8
5.7L V8: 11.8 / 11.2
Old 07-13-2010, 02:24 PM
drago1217's Avatar
Well **** I guess I should have looked some more lol well sorry for the retarded post. Time to drain some
Old 07-13-2010, 02:27 PM
killagt's Avatar
lol u havent drain it yet ? what oil filter did you use ? are you using big version filter ? it hold about half or more quart, and help trap more dirt then small filter.
