Pass or fail?????
Old 07-17-2010, 04:28 AM
02 camaross91's Avatar
Default Pass or fail?????
I have a 2002 camaro ss with 138,000 miles on it. i just swapped the stock cam for the asa gm cam with .525 lift. when i installed it the stock ls1 valve springs appeared to be in good condition as well as the rods and timing chain and bearings. i want to know how many miles i will be able to go without a spring floating or my engine blowing up. so feel free to post ur comments on what u think will happen..... plz post i need opinions
02 camaross91 is offline
Old 07-17-2010, 05:20 AM
Purple98Z28's Avatar
Man that car sucks *****!
Purple98Z28 is offline
Old 07-17-2010, 06:37 AM
garygnu's Avatar
you can't tell if valve springs are good buy looking at them.install new springs using a onhead spring compressor from the ws6 store.
garygnu is offline
Old 07-17-2010, 07:42 AM
Default Yes I do agree, however!
Maybe he's referring to how much pitting is in the springs. I've seen in the past that pitting occurs due to continues stress and load/heat even with how corse the material is.
Old 07-17-2010, 09:53 AM
crainholio's Avatar
You should patent your visual spring fatigue analysis and coil bind assessment process.
Most of us idiots have to check the manufacturer's specs and use compressors, micrometers, etc. Your way sounds much nicer.
But seriously, the springs weren't rated for that lift when they were new. They're at 138K miles now, and I wouldn't even run them w/ the stock cam with that much mileage on them. Forget about a .525" cam.
crainholio is offline
Old 07-17-2010, 10:00 AM
batboy's Avatar
With that much mileage, valve spring, pushrods, timing chain, and oil pump should all be changed if you are swapping in a hotter cam.
batboy is offline
Old 07-17-2010, 12:38 PM
well we will see its either my engine will blow up or it will run for a bit.. personally i just want to get a rebuild out of a blowned motor.
Old 07-17-2010, 02:42 PM
99Bluz28's Avatar
Question
Why wait, Just pull the engine and have it rebuilt now.
Isn't that what you want to do anyway?
99Bluz28 is offline
Old 07-17-2010, 02:50 PM
ULTIMATEORANGESS's Avatar
why put a cam in and not try to get the most out of it?
ULTIMATEORANGESS is offline
Old 07-17-2010, 02:51 PM
yeah but the cam is so mild i think i can get at least another 20,000 more miles out of it with this slightly more aggresive cam. and that will give me time to save up for a hell of a rebuild. and i also have full exhaust and intake so at least the cam can breathe.
long story short i just wanted to see what ppl think cause everyone doubts the 02 ls1 and says cant handle much and u have to do all of this **** to it to make it strong for any aftermarket eternal mods. but like i said this cam isnt far off from the stock one and i have looked everywhere and i think i am the first one to try this on stock ls1 heads. so if anything it will be a learning experience for all ls1 owners on how amazing the stock ls1 is and how indestructible they r. and feel free bad mouthing me all i dont care i just want feedback even if it like ur an idiot or ur car is goin blow and what not.
Old 07-17-2010, 02:55 PM
this cam is so mild i am goin get the most out of it because the old one was sloppy torn up so i will get the most out of it... and i appreciate the feedback.
Old 07-17-2010, 02:58 PM
LS1MCSS's Avatar
You'll probably get 50% of what you want.
LS1MCSS is offline
Old 07-17-2010, 02:59 PM
Gaunt's Avatar
You are wasting your money. Save it until you can make the engine you truly want.
Gaunt is offline
Old 07-17-2010, 03:04 PM
i can't say exactly what kind of hp i will get out of it after the tune but like i said there is a first time for everything its not a waste of my money if i am helping my engine breathe better???????
Old 07-17-2010, 03:05 PM
haha i am pretty sure its the drive part lol
Old 07-17-2010, 03:21 PM
actually i am not the first one to do this and be succesful. stock ls1's r amazing!
SSMOKEN tag in another thread:
"i did a cam swap at 135k. i still have stock lifters and im about 140k now."
__________________
2000 SS | PTC 4000 | 100shot TNT | Performabuilt lvl 2 | QTP | LM1 | El Toro |
http://www.facebook.com/#/profile.ph...e&id=507144160
NX kit for sale $270https://ls1tech.com/forums/parts-...09-nx-kit.html
Old 07-17-2010, 03:25 PM
Gaunt's Avatar
Even if it lasted fine, which is possible, if you are just going to change it in 20k miles anyway, there is no point. Do it right the first time. If you can avoid going through the motor all over again, I would take that opportunity. Unless you want a learning experience, they by all means, go ahead with it.
Gaunt is offline
Old 07-17-2010, 03:35 PM
black00ssFL's Avatar
You know the difference between a lifter and a valve spring is right? And you know what coil bind is right?
black00ssFL is offline
yeah i see what u mean cause going through that motor is a nightmare and the labor on it is outrageous but i mean when it fails i could also get an engine swap and a bunch of different possibilities that r up in the air. but for now this i would just like to see what will happen and how long this will last for and like the previous quote said some guy did the same thing and it ran fine 5k after and is still running so all and all i will come to the road of motor issuses such as floating vaves bent rods and what not but not til later. and then i can worry about what i am goin do. i appreciate the feedback btw
Old 07-17-2010, 03:36 PM
yes...... i dont see where u getting to??
