Engine Rebuild Kit
Old 08-10-2010, 10:33 AM
Chaos07's Avatar
Default Engine Rebuild Kit
My '00 Trans Am has about 167K miles on it and im looking into an engine rebuild kit but its hard to find a kit for a good price...i know summit has 1 for 600. Im not gunna be doing an all out performance build to the engine just try n keep it stock to a few bolt ons like headers and build the heads up and a cam nothing big just a 220 or 224. i just want to rebuild it with all new pistons bearing gaskets etc. who sells a kit for that application.
Old 08-10-2010, 11:01 AM
redz_02's Avatar
600 bucks is pretty cheap for a rebuild kit.
Old 08-10-2010, 11:12 AM
Internet Mechanic
BlackScreaminMachine's Avatar
It's always recommended you send a block out for inspection and cleaning, also to get it ready for a rebuild kit. That does cost a little bit of $$$ but its good practice and piece of mind.
I have seen some guys basically tear down a motor, clean surfaces, wash it out, hone the cyl (clean up), re wash, dry, and then throw it back together and paying minor attention to clearences and TQ specs and run fine.
So take it for what you will.
Old 08-10-2010, 11:36 AM
Chaos07's Avatar
good advice bout the block cleaning
Old 08-10-2010, 02:45 PM
Jeff Smith's Avatar
curious...what about pistons/crankshaft, lifters been over 167K miles, does those need replace new? or could be re-use?
Old 08-10-2010, 02:55 PM
pwrtrip75's Avatar
I just pulled the engine on my vette w/ 160k on it. Pistons were perfect. I put new rings, bearings, oil pump in it and thats it.
If they are in perfect shape, the factory machined surface is still on the outside.....i dont see a reason to replace them.
160k on these....the fine machine lines are still all the way around with no scuffing.
Old 08-10-2010, 03:14 PM
Chaos07's Avatar
good to know if the pistons r good i just get a re-ring kit...and replace gaskets lifters rods springs n get a new cam i already have a new oil pump n timing chain sittin around...if the pistions look good then hey no need to mess around
Old 08-10-2010, 04:17 PM
Jeff Smith's Avatar
Finally, got answered..Thanks
Old 08-10-2010, 04:21 PM
Jeff Smith's Avatar
I ll post it here when I take off the pistons that already run over 215k. It still looks good all 8 psitons.
Old 08-10-2010, 07:07 PM
Internet Mechanic
Eastwood sells home Magnaflux kits, a good investment to check for stress cracks you cannot see with your naked eye.
