1991 S10 LQ4 Project
Old 09-04-2010, 09:51 AM
Clay_SS's Avatar
Default 1991 S10 LQ4 Project
I've been working on this truck for a long time, it's slowly coming together finally, here is some pics of the progress.
LS1 intake
Interior
Mahle Pistons
LQ4 Block
TH350 trans
Crossmember for CTS V oil pan
CTS V Oil Pan
Old 09-04-2010, 10:40 AM
MikeG's Avatar
Should be a quick truck. Where are you in Ohio?
Old 09-04-2010, 10:51 AM
Clay_SS's Avatar
Outside of lima in the lil town of cridersville
Old 09-05-2010, 08:54 AM
Clay_SS's Avatar
Rear crossmember added and spare tire mount removed
Head Studs
853 Heads
3 way adjustable shocks
12 way adjustable shocks
Old 09-05-2010, 04:03 PM
pmgm's Avatar
Nice start... What numbers are you looking to run? Also how big of a shot do you plan on using?
Thanks.
Old 09-05-2010, 05:26 PM
Clay_SS's Avatar
I'm trying to get close to 400 at the wheels on motor, so I think that should make a mid 11 second truck, once I get used too it I'll probably go with a 150 shot.
Old 09-05-2010, 07:43 PM
MikeG's Avatar
Nice, I'm in Lima going to UNOH. What track do you plan on running at?
Old 09-05-2010, 09:45 PM
Clay_SS's Avatar
Probably run at MCIR Norwalk and sometimes go over to indy.
Old 09-06-2010, 08:41 PM
teamblackandred's Avatar
bad *** bro im a huge s10 fan keep us updated
Old 09-17-2010, 04:58 PM
Clay_SS's Avatar
1 7/8 headers
Old 09-17-2010, 06:32 PM
CalamitySS's Avatar
Looks nice! Good job and keep it up. I had a 90 with a 4 cyl. It was a fun truck. I wish I could convince my dad to swap it.
Old 09-24-2010, 03:52 AM
hotrodscrap's Avatar
Keep us posted, I'm curious to know how the headers install.
-SS
Old 11-22-2010, 09:55 AM
Clay_SS's Avatar
A little update. Headers went on alot easier then I had expected. no issues going around the frame all and all they're a good fit. I had to remove the tube on #5 cylinder because my steering shaft is going to need replaced or modified. Here are some pictures.
Old 12-01-2010, 04:49 PM
Tx98Formula's Avatar
what kind of rear end are you running? I might be picking up a little newer s10 here soon and doing either a 5.3 or LQ4/9 swap, just trying to peice together everything i'm going to end up needing
Old 12-02-2010, 06:27 AM
97s10ls's Avatar
You can use either a 8.5 from a newer s10 or a ford 8.8 which are cheap but they are wider then stock. You can just cut the long side of the rear to match the short side and use a short side axle. I paid 175 for a complete rear with 3.73 and discs.
Old 12-03-2010, 09:01 AM
Clay_SS's Avatar
Right now it just has a stock 10 bolt under it. I'm probably going to use it untill I can upgrade, I'll just have to be careful and take it easy! I'm going to end up with a 9 inch under it.
Old 12-14-2010, 07:57 PM
Ws6kid.'s Avatar
I like it!
Quick Reply: 1991 S10 LQ4 Project
