Coated rod and main bearings.
Old 09-04-2010, 01:14 PM
Rob94hawk's Avatar
Default Coated rod and main bearings.
Gonna go with coated Durabond cam bearings. Does anyone make coated rod and main bearings? Or overkill? Thanx
Old 09-04-2010, 01:17 PM
brucer's Avatar
i think overkill.
i like the regular ol' clevite main and rod bearings..
Old 09-04-2010, 01:19 PM
Rob94hawk's Avatar
Hey brucer, what are the signs I should get the crank polished?
Old 09-04-2010, 10:05 PM
fleetmgr's Avatar
Check this
https://ls1tech.com/forums/advanced-...-bearings.html
Old 09-04-2010, 10:22 PM
brucer's Avatar
generally if i can run my fingernail across the journal and it catches on anything, groove, knick,whatever i will have it polished.. i will also check for taper, if i remember correct its like .0005 taper...
Old 09-05-2010, 09:58 AM
Rob94hawk's Avatar
Thanx brucer. I'm guessing the balancing really isn't going to change much with fresh rod bearings.
Old 09-05-2010, 10:51 AM
brucer's Avatar
if your just freshening it up with new bearings and rings theres no need to balance...
you can have a stock rotating assembly balanced and it will make a stock engine run smoother and rev better.. can help it last longer also..
Old 09-05-2010, 11:15 AM
Rob94hawk's Avatar
but then I'll have to get an aftermarket zero balanced flywheel. Doesn't seem like a bad tradeoff.
Quick Reply: Coated rod and main bearings.
