cheap or home-made accesory drives
Old 09-22-2010, 05:10 PM
brian.harmon1974's Avatar
Unhappy cheap or home-made accesory drives
ive looked around the forums but havent come up with anything. does anyone know of a cheap accesory set up that i can use on a 5.3. its going in a 74 chevelle and i need altenator, power steering, water pump and crank. if not any one know where i can find a blue print of a camaro or corvette accesories set up so i could posibly make my own?
Old 09-22-2010, 06:45 PM
jman32779's Avatar
Use the truck brackets with an idler re-locate. The brackets are easy to find and inexpensive.
Old 09-22-2010, 07:14 PM
zipster's Avatar
Brian,
Check my photobucket, I am the king of cheap!
http://s392.photobucket.com/home/zipster93/index
Click on each photo, there is an explanation of what was done. If you have any q's contact me.
Old 09-22-2010, 09:27 PM
71ANTICARB's Avatar
Zipster your ps setup is exactly what I was planning on doing, but wound up just using the f body setup. Brian if you decide to use the truck stuff let me know I have some laying around. If you need some more info on the f body stuff let me know, I can get you some measurements or whY ever you need.
Old 09-22-2010, 10:25 PM
zipster's Avatar
I am all about "use what ya got".Why buy different brackets if you have ones that could work?
Old 09-22-2010, 11:57 PM
gofastwclass's Avatar
...and why guess if the expensive handiwork of someone else will fit your custom application?
I did the same as Zipster for the PS pump but made a bracket for the alternator that mounted where the AC compressor was. I used the factory (for the swap car) compressor in it's factory location and created idler and tensioner pulley mounts for the occasion. Look at my build topic in my sig for pictures and PM me for questions if you have them.
Old 09-23-2010, 10:51 AM
zipster, your my idol right now, did u just bolt everything into holes that ever availbable in the cyclinder head and block? also what are you doing 4 an idler/tensioner?
and yes im interested in P/S and altenator parts, finally got some down time to start the swap, when i do i will have a full thread to look at because none seems to like the 73-77 body style
also what is there to use for cheap motor mounts? and if theres anything i can fabricate myself im not scared of a welder or plasma cutter, have access to them anytime i need them and am a fairly good fabricator
Old 09-23-2010, 06:37 PM
chevboy28's Avatar
just get the ls1 motor plates that you just bolt onto block and then mount some sbc brackets on to they're like 40 bucks on ebay or you could make em not worth the time though
Old 09-23-2010, 10:18 PM
thedrill's Avatar
Default home made
I managed to use a Toyota previa power steering pump on a custom mounting bracket and an Audi A6 120A alternator also on custom mounting brackets, but using existing mounting holes in the block and head.
The Toyota pump is also silent in operation and fully rebuildable with a seal kit from Toyota.
Power steering Pump cost $12 and alternator $15, used from junk yard.
Old 09-24-2010, 06:11 AM
Pop N Wood's Avatar
85 amp Denso alt off a 91 Celica, mated to a pulley off a Supra. The mini alternators sold by the speed catalogs are just Denso alternators. It is a couple of inches smaller in diameter than the Delco units.
JY charged $20 for alternators around here, so guess mine is the high dollar solution.
Old 09-24-2010, 09:39 AM
neal64ss's Avatar
Zipster, you sir are the "King of cheap", and I am envious.
Old 09-24-2010, 11:00 AM
thanks for all the ideas guys, now i can start brainstorming my solution. this is on hold 4 a bit because the stars aligned for me and im getting a 94 4l60-e and i gotta look into what it takes to get it into the chevelle behind the small block so i can start driving it again. any one got ideas? gonna look at the transmssion section pretty hard
Old 09-25-2010, 11:27 AM
zipster's Avatar
[QUOTE=brian.harmon1974;13902013]zipster, your my idol right now, did u just bolt everything into holes that ever availbable in the cyclinder head and block? also what are you doing 4 an idler/tensioner?
Tensioner is a turnbuckle on the alternator, they are available from most decent hardware stores. Usually under $5.00, The way I routed the belt, there is no need for an idler.
http://i392.photobucket.com/albums/p...g?t=1285432191
Also used the bolts from the tensioner to mount alternator, just had to space it out it align it with the crank. Used existing holes and hardware.
Old 09-25-2010, 12:44 PM
Cool
ooo i c now, i dont know how i missed that, its like what i have on there as a stock piece for the V-belts that are on the small block thanks again
Old 09-25-2010, 04:06 PM
rumblbu's Avatar
Am I the only one wondering about the minimal amout of belt wrapped around the lower pulley and water pump on that first set-up? I would think belt slippage would be an issue. Seems like mounting the power steering pump higher might help both concerns I have though.Just my .002
Quick Reply: cheap or home-made accesory drives
