Heads/Cam (243's/TR230) Dyno day 10/19/10! ~ Track results here!
Old 09-29-2010, 06:03 PM
caseypryan's Avatar
Talking Heads/Cam (243's/TR230) Dyno day 10/19/10! ~ Track results here!
Please no negative comments about what you think about the set up I chose.
TR230/224
243's milled .020
7.4 push rods
LS7 lifters
Patriot duals
Melling high volume pump
PS LT's ORY through SLP D/D or electric cut out
http://www.youtube.com/watch?v=NDTKa...os=SO67xYwkmdA
392rwhp 376rwtrq (STD)
This is the first day. All this took about 1.5 hours of work.
First I took off the intake assembly..
Then the throttle body
These are all 4 of the sensors that had to be disconnected from the lid/throttle body
Then took out the 3 water pump bolts on the drivers side
Then took the other 3 off on the passenger side
Water pump gone..
Then took off the AC condensor and radiator
Old 09-29-2010, 06:06 PM
sjsingle1's Avatar
looks good so far
Old 09-29-2010, 06:08 PM
caseypryan's Avatar
Thanks..I plan to take pictures along the way. Should be done in 2 weeks max..
Old 09-29-2010, 06:30 PM
Z98BOYA's Avatar
what kind of exhaust it that casey? i really want those tips and will they hook up to a magnaflow?
Old 09-29-2010, 06:40 PM
caseypryan's Avatar
The exhaust is SLP center mount exhaust...You can get it reproduced by 6LE on here or check ebay...
Old 09-29-2010, 06:41 PM
Snake_Skinner's Avatar
What H/C setup you going with?
Old 09-29-2010, 06:42 PM
1979rs/z28's Avatar
Good work, just as a tip try to get the grounds off the back of the heads before you unbolt them. A 15mm rachet wrench works wonders back there.
Old 09-29-2010, 06:44 PM
MyFirstLS1's Avatar
are you doing it with it in the car, i know i am jumping the gun but i am very curious because i have never seen or heard how people do it in our cars. I was planning on dropping my motor.
Old 09-29-2010, 06:47 PM
masterz28's Avatar
^Yeah some do it in their cars. I plan on doing mine with it out since i want to replace all gaskets, i have 140k on the motor.
Old 09-29-2010, 06:48 PM
caseypryan's Avatar
I am leaving the motor in. You don't need to drop the motor to do heads cam. Check out LS1howto.com for a more in depth write up.
I'll definitely do that. Thanks for the tip! :thumbsup:
TR230 and stock 243's milled .020
Old 09-29-2010, 06:50 PM
MyFirstLS1's Avatar
ok cool, thanks for that little tip but that reminds me my oil pan gasket is leaking so it would be beneficial to pull it
Old 09-29-2010, 06:53 PM
caseypryan's Avatar
Yeah I'm not dropping my oil pan or changing those gaskets since I only have 50k
Old 09-29-2010, 07:13 PM
98z8uup's Avatar
Good luck with the build.
Old 09-29-2010, 07:34 PM
beedo's Avatar
Hey casey, Just took my car around the block with the new TR230 cam in it, feels really good with my **** tune! I am running a 6.0 with 317's milled .020 your gonna really like the milled 243's luck ***!
Old 09-29-2010, 07:40 PM
Mr. Quick's Avatar
Smile
Good luck, same cam as me, love it!
Old 09-29-2010, 09:36 PM
caseypryan's Avatar
Thanks guys! I'm really excited to get it all finished. I just pulled the intake manifold and power steering pump off. I'll post pictures
Old 09-29-2010, 09:50 PM
1979rs/z28's Avatar
Looking good man, I see you pulled the pulley off instead of wrenching behind the pump (it sucks)
Old 09-29-2010, 09:54 PM
AW794's Avatar
Nice progress man. Shoot me a PM if you need some help on something, i just finished my build. You can also reference my thread if you need
https://ls1tech.com/forums/generatio...-am-build.html
Old 09-29-2010, 09:55 PM
AW794's Avatar
You might have to (drop the pan a little), to gain access to the oil pickup tube bolt.
Old 09-29-2010, 09:59 PM
01cherryreds10's Avatar
Thank god I don't have an F-body looks pretty crammed in there haha old cars woo
Quick Reply: Heads/Cam (243's/TR230) Dyno day 10/19/10! ~ Track results here!
